Good and Bad Service Call
Old May 20, 2004 | 12:20 PM
Dem0s's Avatar
Default Good and Bad Service Call
I took my xfire into the shop this week.
Problem 1 - Wind noise from the top front of the windows.
Solution - Chrysler says that this is normal for the car. :cry: Does any one else have this issue. Sure I can just turn up the music but it is annoying at times.
Problem 2 - Hade some vibration in the drive train, namely the shift **** and the steering wheel.
Solution - ALL four tires were out of balance. They fixed this one and she drives great now.
I am still annoyed that Chrysler is saying that the wind noise is normal. I have NEVER had a car that had this issue. :roll:
Old May 20, 2004 | 12:21 PM
Heb80's Avatar
Default Re: Good and Bad Service Call
Use the search button.
Old May 20, 2004 | 12:31 PM
DFWSBR's Avatar
Default
There are two TSB's or Technical Service Bulletins out on Wind Noise. Have the dealer pull them up. See the TSB section of this site. It will assist you and the dealer on pulling up the right information.
If you have any further questions, please let us know.
As for the vibration, have the dealer check the transmission / motor mounts. You should not have any vibration what so ever.
Good luck.
Old May 20, 2004 | 12:32 PM
Cyril Baldwin's Avatar
Default
Check it here for the TSB
https://www.crossfireforum.org/forum...pic.php?t=1792
Old May 20, 2004 | 12:46 PM
Dem0s's Avatar
Default
I took it in once before and they did the first TSM, they said the "new one" was the same one they had already done. I am going to check the TSB # with the service rep to see which ones they have done to the car.
Thanks for the prompt responces!!
Old May 20, 2004 | 12:48 PM
Default
It took me 2 trips to have my wind noise done after I had my Crossfire...they do it that way :lol: First trip...don't know how to fix it ( being the only Crossfire running around town) Second trip, they've seen the TSB from this forum
Old May 20, 2004 | 12:51 PM
Dem0s's Avatar
Default
So it is not "normal" and can be fixed. I am glad there is hope!!
Old May 20, 2004 | 12:59 PM
Dem0s's Avatar
Default
The vibration went away when they balanced the tires.
Old May 20, 2004 | 03:16 PM
VegasCrossfire's Avatar
Default
:shock: I'm scared to death to take it in for wind noise for fear they will screw something else up!! How sad is that? I'd rather live with the wind noise than to take a chance ops:
Old May 20, 2004 | 03:25 PM
DFWSBR's Avatar
Default
Not much to screw up at all. Simple adjustment.
Old May 20, 2004 | 04:55 PM
Number1500's Avatar
Default
Took mine in for wind noise under the first TSB & tech adjusted it but didn't like the way it looked so he ordered a new weather strip. Installed new strip & no wind noise. It took about twenty minutes. So there is hope.
Old May 20, 2004 | 05:30 PM
krusty_the_klown's Avatar
Chrysler isn't saying that, your Five Star Loser is saying that. Lazy MFers.
Old May 21, 2004 | 05:14 PM
Dem0s's Avatar
Default
Is that the weather strip that goes on the top of the door opening? They already replaced the little triangle one on the door.
Old May 21, 2004 | 05:18 PM
Default
Probably this one......
Roty135
17
Oct 11, 2018 10:11 AM
jgreen
106
Sep 18, 2017 11:46 PM
Aug 18, 2015 12:52 PM
axnguyen
Jul 21, 2015 11:41 AM
Rusty475
Jul 13, 2015 10:03 AM
