wipers shutting off when being used!?
Old Sep 28, 2011 | 07:25 AM
lifeistiming's Avatar
Default wipers shutting off when being used!?
anyone else have this problem?? what was the fix? ...turn wipers on in rain and they stop completely at random times, but always come back on again by themselves. dealership couldn't find anything wrong. help!
Old Sep 28, 2011 | 07:47 AM
witchal's Avatar
Default Re: wipers shutting off when being used!?
Does this happen when you're at a stop? If so, it's normal. The wipers automatically go into intermittent mode when the vehicle isn't moving.
Old Sep 28, 2011 | 07:57 AM
Bigkid's Avatar
My thoughts too.
Old Sep 28, 2011 | 08:12 AM
they shut off at all times.....first time in heavy downpour while car in motion....most times after car has stopped and then started moving again. i've read when batteries are old they can cause funny things to happen,,,,think that's the problem?
Old Sep 28, 2011 | 11:18 AM
AlG's Avatar
AlG
Sounds more like a bad connection where water is getting in somewhere and shorting them out. I would try spraying the front of the car with a hose or maybe taking it through a car wash and getting it good and wet and see if it happens. If so, then the wiring needs to be checked.
Old Sep 28, 2011 | 12:50 PM
Where abouts in the cycle do they stop? In the park position or any random spot. The position they stop is an important indicator of the cause of the problem.
Old Sep 28, 2011 | 02:20 PM
they stop in any random spot...doesn't matter if they're on high or low,,, if i'm moving or sitting
Old Sep 28, 2011 | 02:31 PM
The Service Manual describes a list of the tests that can be done to check the operation of the wiper motor, switch, wiring and the BCM for faults. Check the ground and fuse connections first, probably not them but they are easy to check.
syfi
Mar 28, 2026 04:14 PM
Valk
Jul 12, 2021 09:49 PM
Franc Rauscher
May 9, 2016 12:04 PM
hecti
Oct 7, 2015 06:11 PM
williammt
Sep 6, 2015 11:23 AM
