Starting Issue
Old Oct 6, 2011 | 01:18 PM
Wilsy's Avatar
Default Starting Issue
Hi all,
Can anyone give me any pointers to what the problem might be? I havent had it plugged in yet so don't know if its throwing any codes. Guess I'm just trying to save the £50 the local garages are asking to plug it in if its a common problem.
Symptoms:
Starts from cold first time, everytime
Once warm the engine turns over but doesnt start - will eventually start after about 3 or 4 tries.
At the point that it does fire I can feel some movement on the clutch pedal like a 'clunk'.
The car runs perfectly well all the time once its been started.
Thanks in anticipation.
Rick.
Old Oct 6, 2011 | 02:36 PM
Kodebuster's Avatar
Default Re: Starting Issue
Not sure about the Cluch Pedal 'Clunk", but if it starts cold and fails hot, possibly the CPS is getting flakey.
Search CPS for additional details.
Typically a faulty CPS will allow a cold start, but kill engine once hot. Let it sit a little to kool, and it starts right up.
If the starting and Clutch noise are remotely related to your issue, then possibly not CPS related.
I'm not sure how a Clutch Clunk after starting could be associated with hard starts when warm, but nothing would surprise me lately...
And you need to pull the Codes...this will narrow your adventure...
Old Oct 6, 2011 | 02:59 PM
Wilsy's Avatar
Thanks for this! Do you mean camshaft or crankshaft position sensor?
Old Oct 6, 2011 | 03:52 PM
Originally Posted by Wilsy
Hi all,
Symptoms:
Rick.
Spend some of the 50 quid to buy your own reader and then you'll be set for any future problems.
I had a problem on another car like this and I beat my brains silly trying to solve it.
It turned out that the fuel pump was not reaching the normal pressure and starving the injectors, when cold the car would start because the injectors sprayed a richer mixture and the car would catch but when warm the injectors sprayed too little fuel for that little kick needed when starting. Normal driving was fine unless you stomped on the gas.
Old Oct 6, 2011 | 04:14 PM
Wilsy's Avatar
Didnt realise they were so cheap!! Just bought one
U480 Car Diagnostic Scanner Code Reader OBD2 CAN EOBDII | eBay
Old Oct 6, 2011 | 11:41 PM
Kodebuster's Avatar
The cold running and hot failure I described is associated with the Crankshaft Position Sensor (CPS), not Camshaft...
Old Oct 7, 2011 | 03:41 PM
OKC-XFR's Avatar
Hi all,
Symptoms:
Rick.
I had the exact same starting problem with mine - took it into the dealer under warranty and they replaced the fuel pump. It has been starting perfectly since.
Old Oct 7, 2011 | 06:18 PM
Buy one here : Your Parts Search Returned 1 Part(s)
Old Oct 10, 2011 | 05:38 AM
Wilsy's Avatar
Hi all,
Got the following codes from the Crossfire: -
P0341
P0403
P0410
P0412
Does this shed any light?
Regards,
Rick.
Old Oct 10, 2011 | 06:41 AM
Hi all,
P0341
P0403
P0410
P0412
Regards,
Rick.
(P0341) CAMSHAFT POSITION SENSOR
PERFORMANCE . . . . . . . . . . . . . . . . . . . . . .9-346
(P0341) CAMSHAFT POSITION TIMING
OVER-ADVANCED . . . . . . . . . . . . . . . . . . . .9-344
OVER-RETARDED. . . . . . . . . . . . . . . . . . . . . .9-340
(P0400) EGR SYSTEM PERFORMANCE . . . . . .9-350
(P0403) EGR CONTROL CIRCUIT . . . . . . . . . .9-354
(P0410) SECONDARY AIR INJECTION
RELAY CIRCUIT . . . . . . . . . . . . . . . . . . . . . .9-362
SYSTEM. . . . . . . . . . . . . . . . . . . . . . . . . . . .9-356
(P0412) SECONDARY AIR INJECTION
SWITCHOVER SOLENOID CIRCUIT . . . . . . . .9-365
I'd go with the Camshaft Sensor first.
( and what the heck, I'd also throw in a Crankshaft Sensor while I was at it )
Lots of info on that in threads, do a search.
Old Oct 10, 2011 | 06:55 AM
Wilsy's Avatar
Will do - is this the part??
Sensor, camshaft position MERCEDES-BENZ W202 W203 CL203 | eBay
Old Oct 10, 2011 | 07:05 AM
bluecoupe's Avatar
Yes, says it is for an R170 so that's the correct one. Good luck!
Old Oct 10, 2011 | 10:14 AM
Wilsy's Avatar
Thanks for that - just ordered the part!!
Old Oct 14, 2011 | 06:14 AM
Wilsy's Avatar
Ok, replaced the Camshaft Position Sensor (5 minute job!) and the starting issue hasn't gone away.
Any more suggestions?
Regards,
Rick.
Old Oct 14, 2011 | 08:43 AM
tighed1's Avatar
Try this...
Originally Posted by alaxfire
...( and what the heck, I'd also throw in a Crankshaft Sensor while I was at it )
Old Oct 14, 2011 | 08:46 AM
Regards,
Rick.
Clear the codes and see what new codes are set. My money is on the fuel pump still. Can you get the pressure that the fuel pump puts out tested.
Old Oct 30, 2011 | 01:39 PM
Wilsy's Avatar
Originally Posted by tighed1
Try this...
Just ordered - fingers crossed again
Old Oct 30, 2011 | 05:45 PM
6000rpm's Avatar
That P0410 could be the Relay Control Module's solder going bad. That's the code I got before the starting and stalling problems I had.
KDW4Him
18
Sep 1, 2021 05:47 PM
PNA
Nov 12, 2020 04:44 PM
northwest_crossfire
May 30, 2016 05:19 PM
Bayukbros
Jul 17, 2015 11:21 AM
FIXRE
Jul 9, 2015 09:16 PM
