2'' lowering springs
Old Oct 9, 2011 | 12:51 AM
05CrossfireCid's Avatar
Default 2'' lowering springs
does anyone know of any sprigs that lower 2'', right nowi have the h and r springs and it lowers 1'' in front and 1.3'' in back but i want it lowr for that more exotic and agressive stance, post if you know of 2'' springs for the xfire.
Old Oct 9, 2011 | 07:08 AM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: 2'' lowering springs
i had the slk eibach pro-kit springs and they dropped it over 2".
Old Oct 9, 2011 | 09:47 AM
that white xfire looks gub bro, how do u post pics ad ill putmyup
Old Oct 9, 2011 | 10:45 AM
i looked up the slk eiback pro kit springs but i onlyfound it where it said lowering from 1'' to 1.5'', i want tha 2'' like urwhite one. right now im on h and r springs and its 1'' in the front and 1.3'' in te back but like i said i want 2'', if you could post the exact number or where i could find it i wouldmuch appreciate it sir.
Old Oct 9, 2011 | 10:54 AM
Mopar or No Car's Avatar
Be prepared to spend a few dollars modifying your suspension or you will ruin a set of very expensive tires in 5,000 miles. You will need the factory front camber adjustment kit (hope that's good enough but only gives you .5 degrees) and an aftermarket rear camber adjustment kit. Experience talking.
Old Oct 10, 2011 | 09:14 AM
+1 and I hope you have a good shop to try and align it afterwards...
Old Oct 10, 2011 | 03:05 PM
andrew's Avatar
Originally Posted by 05CrossfireCid
i looked up the slk eibach pro kit springs but i only found it where it said lowering from 1'' to 1.5'', i want tha 2'' like ur white one. right now im on h and r springs and its 1'' in the front and 1.3'' in te back but like i said i want 2'', if you could post the exact number or where i could find it i would much appreciate it sir.
~ the eibach numbers are conservative...
additionally, i never made any additional suspension mods after my alignment... yes the rear has negative camber but my tires lasted 25k or so with the lowering springs and koni shocks i later added.
hope this helps.
(they lowered the car approximately 2" ... as seen in pics below) ...
Old Oct 10, 2011 | 04:06 PM
JHM2K's Avatar
Originally Posted by andrew
Favorite shot ever.
Old Nov 16, 2011 | 04:58 AM
TommyT's Avatar
hope this helps.
hey I know this is a few weeks old but what size tires are you running for a reference?
Thanks
Old Nov 16, 2011 | 07:04 AM
andrew's Avatar
~ oem sizes.
i also added h&r wheels spacers to push the wheels out to the fender edge providing a more aggresive stance.
Old Nov 16, 2011 | 11:34 AM
frankeyser's Avatar
Eibach Prokit Springs for SLK dropped mine 2 inches as well.
Old Dec 9, 2011 | 10:42 AM
edmoncwheeler's Avatar
Lowered CF's look great! I have a set of 4 H&R (1"F, 1.2"R)I bought but am chickening out on trying to install myself. Would anyone make a guess on how much I should spend to have them installed and aligned? I can't get any quotes under $350 here in DFW area.
Thanks
Old Dec 9, 2011 | 03:05 PM
rfors777's Avatar
Thanks
Let me know what you find. I too have the same springs and need a place in D/FW to install them.
Old Dec 9, 2011 | 07:17 PM
MikeR's Avatar
$350 for the spring install and 4 wheel alignment dosent sount too off base to me.... at $90/hr for labor and $85 for alignment (here) that would be about 3 hours labor... I would guess labor to be between 2 to 3 hours actual... what they charge is not actual labor time..
Old Dec 9, 2011 | 08:44 PM
hcarter's Avatar
Cut SRT springs 1 full round dropped the car 2 inches even with new camber bolts in the front I was still too far neg , had to get K-macs to get to spec on the front . seems to me I have seen many different setups some are able to get their alignment right and others are not< IMO new camber bolts are a shot in the dark when car is lowered 2" or more. It has been a learning experence for me
Old Dec 18, 2015 | 06:50 AM
Kadir's Avatar
~ oem sizes.
Hi there, could you please tell me what size wheel spacers have you used? and used them for both front and rear? I would like to get a pair of 15mm for the REAR only and not sure what would be the side effects.
Thanks
Old Dec 18, 2015 | 12:58 PM
Thanks
The side effects would be 15mm.
Sorry, I could not resist.
This thread is 4 years old.
55chevy
Jul 22, 2024 02:31 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
Power Sedan
Sep 20, 2015 09:24 PM
ayebb
Sep 18, 2015 03:35 PM
