Reset Air Pressure
Old Oct 19, 2011 | 04:04 PM
aviram's Avatar
Default Reset Air Pressure
hello i would like to reset the air pressure\cancel this. How can i do that?
Thanks
Old Oct 19, 2011 | 04:23 PM
Thirteendog's Avatar
Default Re: Reset Air Pressure
Thanks
Are you trying to say your Tire Pressure light is on and you'd like to turn it off?
Old Oct 19, 2011 | 04:34 PM
Chris L.'s Avatar
Either add air to your tires or relocate to a warmer environment.
Old Oct 19, 2011 | 04:46 PM
It don't get much hotter than Israel ........
Old Oct 19, 2011 | 04:54 PM
Thanks
They are a pain in the ***. Either the unit itself is bad, or your air pressure is off. Equalize your tires to the correct air pressure.
Old Oct 19, 2011 | 06:13 PM
IBLUBYU's Avatar
It is claimed that the TPMs have batteries that last for 10 years ..... but if one goes out, you'll never know which one, unless you replace them 1 at a time. A real pain in the A$$ and not reasonable. So ALL would have to be replaced. Better to just check your pressure regularly and put a small piece of black electrical tape over the light on the dash. Shalom
Old Oct 19, 2011 | 07:55 PM
Rudy ( rcompart ) had posted this fix :
Easiest way to disable it is to remove the wire from pin 2 (red) and put it in pin 6 (blue). This will completely disable it and you will no longer have the light illuminate on the instrument cluster. This will not affect the HomeLink in any way so you don't lose that functionality.
To get at the TPMS/HomeLink connector, just remove the dome light and you can see the wires going into it. Remove the connector, use a pick or other fine tipped tool and depress the top of pin 2 so it will slide out. Push the pin back into the connector in the 6th position and reinstall the connector. Reinstall the dome light and you are finished.
( tried to copy the diagram, no luck. Search for the sticky "disable tpms" to see the diagram. )
Old Oct 19, 2011 | 08:33 PM
https://www.crossfireforum.org/forum/537700-post3.html
Old Oct 20, 2011 | 01:29 AM
aviram's Avatar
thanks for the information. There's few crossfire here in Israel
Valk
Jul 12, 2021 09:49 PM
TerryR
Dec 13, 2019 03:27 PM
Sep 28, 2015 07:40 PM
stelrz1
Sep 21, 2015 11:18 AM
tritongreen
Sep 18, 2015 07:32 AM
