Ticking On Start Up
Old Nov 14, 2011 | 05:52 PM
Don Hiltz's Avatar
Default Ticking On Start Up
Lately, I've noticed a ticking sound after I start up in the morning. It typically abates completely after a block or two.
I thought it could be an injector, but that wouldn't go away.............correct???
Therefore, I've concluded that it's a lifter which is oil deprived until it receives lubrication from the crankcase. Does that make sense?
I just had the oil and filter changed; the ticking persists.
Is this an unusual event? Should I be concerned?
Thanks in advance.
Don
Old Nov 14, 2011 | 07:38 PM
Default Re: Ticking On Start Up
They all seem to do this somewhat Don....My roadster is more noticeable than the coupe...
Old Nov 14, 2011 | 08:15 PM
tighed1's Avatar
My "new" coupe sounds like a diesel compared to my other two Xfs.
Maybe the 166K+ miles has something to do with it???
Still runs like the dickens though!
Old Nov 14, 2011 | 08:40 PM
blackcrossfire07's Avatar
Mine ticks at first too. Been doing that for almost 7 years.
Fact is our engines are noisy.... Because they are a Mercedes. If you want quiet and smooth get a Lexus. If you want noisy and clunky but last a million miles then get a Mercedes. Not trying to be rude... Just want you to know with confidence everything is ok. Some here had this problem to the extreme and had it fixed. But I don't think you have a problem.
Old Nov 14, 2011 | 08:41 PM
Years ago I had a Mercedes 190 that did the same thing. Seems to be common on their engines.
Old Nov 14, 2011 | 08:43 PM
bri3d's Avatar
People on MBWorld say that the type of oil filter (paper v. fleece) makes a difference, especially on V8s with similar designs - did you get the oil filter replaced with a fleece one? If not, it's something to try for less than $15. Although I'm not positive it'll help your noise it's always good to have a non-paper filter. They're better because they can't tear and are extremely unlikely to collapse under pressure.
I wouldn't worry too much about it though, really. These engines aren't nearly as quiet as what a lot of people are used to. I swear my '97 4runner has a quieter valvetrain even with with 250,000 miles on it, even though I always use the recommended 0W40 oil and a fleece filter on the Crossfire (and the Crossfire has less than a quarter the mileage).
Old Nov 14, 2011 | 11:06 PM
Thanks in advance.
Don
Is it possible that you cleaned the wax out of your ears lately?
No matter, as you and the car age you will notice less noise, the car will not be quieter though, you'll just be deafer.
Old Nov 15, 2011 | 02:09 PM
Larry Hitze's Avatar
I read once that the injectors will tick at low engine speed under some conditions due to them having to close under a greater pressure because at low speed they are not open as long. At faster speeds the tick would go away. A lifter ticking would just get to be faster ticking at higher speeds. Again, I'm not a mechanic that's just what I read somewhere. After my 5000 mile trip this summer to Calif. by way of CAA my car ticked alot at low speeds and idle but went away if it was reved up. It did that for a couple of weeks and now it doesn't do it so much.
user 8202
Canada
29
Nov 11, 2015 05:27 PM
xjken
Sep 13, 2015 10:18 PM
lazorouss
Sep 11, 2015 09:16 AM
BEATv1
Sep 10, 2015 12:58 PM
aerobluehal1
Canada
Sep 3, 2015 10:15 AM
