Engine cuts out / limiter kicks in when accelerating??
Old Jan 27, 2012 | 02:29 AM
dom03's Avatar
Default Engine cuts out / limiter kicks in when accelerating??
Hi Guys,
I have a 2004 Limited Crossfire Coupe with 98k (already done a 100k service).
The car started to kick back when accelerating for the first time today and I could barely drive the car over 40-60km/h without the car feeling like its going to cut out and kicking back consistently. I had to really ease on the accelerator but it would still kick back a bit.
It did cut out once while driving, had to kick it back over but started up fine.
Any ideas?
Old Jan 27, 2012 | 03:09 AM
dom03's Avatar
Default Re: Engine cuts out / limiter kicks in when accelerating??
Just took it out a bit after letting it sit off for an hour, still occurs.
Under further inspection it occurs during quick acceleration from standstill and also in any gear, or also around the 3k rev point.
Could it be the fuel pump / sensor / computer?
Old Jan 27, 2012 | 11:49 AM
Originally Posted by dom03
Hi Guys,
Any ideas?
This is a manual transmission? 98k miles or kilometers?
If it was an auto tranny, I'd say it was the electrical plate or similar and you were in limp mode.
Old Jan 28, 2012 | 12:24 AM
Mine acted like this when my fuel pump began to fail.
It also became harder to start with longer cranking times.
Fuel Filters also have been known to cause symptoms like you describe.
Old Jan 28, 2012 | 07:28 AM
dom03's Avatar
Its manual transmission with 98k kilometres.
It ran fine this morning no matter how hard I accelerated, but tonight after driving back home it started to occur again... and mostly happens when I accelerate in the half to full throttle area...
I have to get my mechanic to check it out... could driving the car like this damage anything if its just for a short period?
Old Feb 20, 2012 | 06:09 AM
dom03's Avatar
My mechanics put this down to MAF (Mass Air Flow Sensor) according to his scanner and diagnostics, error kept occuring after attempting to clear it. My air filters were replaced last service so it cant be them contaminating the MAF.
I've ordered a new MAF for $40 including delivery from eBay, I was quoted $165 for a used and $500 for a new one! Thank god for eBay.
I will let you know if this resolves the problem and removes the error code. I am also going to run Toyota Injector Cleaner fluid through the fuel to make it run like new again.
IGot2P
Jul 26, 2025 12:40 PM
bbsrt6
Feb 16, 2019 12:39 PM
BrenLW
Aug 5, 2015 04:53 AM
Rusty475
Jul 13, 2015 10:03 AM
mike28117
Jul 10, 2015 10:51 AM
