Crossfire Exhaust - Modification Sound Improvement
Old Feb 11, 2012 | 03:16 PM
burg1989's Avatar
Default Crossfire Exhaust - Modification Sound Improvement
Hi Guys
I am wondering if anybody has made and (£FREE) exhaust modifications to make there Xfire exhaust sound better i.e. deeper, porsche like?
Thanks for your help!!
Old Feb 11, 2012 | 03:55 PM
boobles37's Avatar
Default Re: Crossfire Exhaust - Modification Sound Improvement
Can't answer the question but I personally think that it sounds awsome as it is. I see you are just up the road from me.....
Old Feb 11, 2012 | 03:59 PM
burg1989's Avatar
I love the noise when it hits 2500/3000 revs but Like the Porsche's I also like the grumble at lower revs
I am in Southampton! Where are you based? I am seeing more and more Xfires around our area! Cannot wait till the Hoy Unfreezes so I can give it a goodold wash!
Old Feb 11, 2012 | 07:47 PM
boobles37's Avatar
I agree that at lower revs, it could sound better.
I am in Andover mate.....
Old Feb 16, 2012 | 02:57 PM
coolx's Avatar
Originally Posted by burg1989
Hi Guys
I took off the engine cover and placed a Spectre air filter right on the MAF - my Crossfire has a really impressive growl and a quicker throttle response...(I did this out of curiosity, not as a permanent mod.)
Old Feb 16, 2012 | 03:35 PM
Kodebuster's Avatar
Hi Guys
A quick Search in the 'Engine & Exhaust' section for 'Resonator' turned up this:
https://www.crossfireforum.org/forum...ns-please.html
Others have gone with a complete Muffler delete, where possible if emissions testing is not an issue.
Search that section on Muffler, Cat Back, and exhaust for all the gory details...
Old Feb 16, 2012 | 03:45 PM
I am not trying to be rude, but I think your brain simply wants to believe it is faster because of the increase in noise. Here on the forum there are dyno results and it is proven that doing what you did will hurt performance. Putting an air element anywhere that it does not have access to fresh air is going to hurt performance because the factory unit sources air from outside the car, and now you are sucking it in from the terribly hot engine bay, especially back at the MAF. Also, an intake may make it feel like a quicker throttle response, but the only way to actually get a quicker throttle response is with a sprint booster in line with your acceleration pedal to modify the output voltages.
You should try a DIY approach like we did, where the air is still sourced from the grill where it is cool, where proven, dynoed gains are made. Much cheaper than other solutions but the results are there. There is a filter in each of the polished canisters...
Old Feb 16, 2012 | 03:54 PM
JHM2K's Avatar
Have you ever measured IAT's on that setup, John?
Old Feb 17, 2012 | 08:00 AM
I believe Max datalogged those things with the original prototype, and numbers were nearly identicle to Needswings DCAI. My butt dyno tells me I am VERY satisfied with the lower temps and lots more power. I am hoping the new hood helps with cooling too
I do not datalog, overkill for an NA IMHO.
rayth
41
Jul 31, 2019 04:02 PM
basti-germany
Jun 24, 2015 11:48 AM
MJPowers
Jun 8, 2015 02:34 AM
turboomni08
Jun 5, 2015 10:46 PM
JEFASOLD
Jun 5, 2015 09:04 PM
