bumpy ride?!?
Hi i am reasonably new to my crossfire N/A i have had it for about 5 months now.
I just want to know what your comments are about the ride quality, I am only 21 so my bones / back should be able to cope well with ALL sports cars fine... i bought the crossfire second hand so i do not know if the suspension has gotten any work on it, the ride to me is really bumpy even on a smooth highway... is this normal? i am seriously considering buying after market suspension/ what ever else i need so i can adjust the ride quality for long drives!
Is there certain tires what wreck the ride? or anything i can easily change i have looked at my shocks/suspension all looks good ect
cheers for any comments.
Tire brand can make a huge difference... The previous owner of my SRT had installed Nittos on the front... very harsh. I had Continental DWS on my Mandrus wheels... even with the tires being shot, the ride improved
So, tires are certainly a contributing factor. If your car has a decent amount of miles on it, a good set of shocks would work wonders as bad shocks will ruin the ride quality. Bilstein shocks are among the best if you're at stock ride height... $400 for a set and they're a breeze to swap out.
Aside from that, the Crossfire is simply a firm-riding car. If you think the Limited is bad, you should drive an SRT-6. The suspension in that car is as comfortable as falling down a staircase.
yeah i was thinking the tires might have a bit to do with the ride , i have cheap tires on now but before hand when i got the car it had decent brand tires on and the ride still felt the same so ill have too look into that thanks , the car has done 100000kms , so miles that would be 60k? not sure thanks i might get those bilstein shocks sounds like a cheapish price to maybe fix or improve the ride.
yeah well i know they made the car very stiff... and you can feel that with the n/a, haha i would love to see the power of the srt-6! thanks for your help
Originally Posted by sk8erjosh09
Hey John, would you happen to have a link for those?? Are there differences between those and stock that would affect tire size more so than stock?
Bilstein HD Shock
Gotta love price bumps...
Awesome!!! Thanks John.... so when you say a breeze to swap out, you talkin 6 pack, 12 or 18?
Break the tension on the upper shock bolts while car is on ground. Place front of car on jackstands. Position jack under the front lower control arm, put some load on the shock. Remove upper nut from shock, and loosen lower bolts. Release tension from jack, you should be able to wiggle the upper portion of the shock free. Remove shock, replace with new one, reverse the process.
Repeat for the rear, the only difference being the removal of trim panels first.
Also, be prepared to grunt a lot on the rears unless you remove the springs. Seating the bottom of the shock in the rear recessed area correctly is a nightmare. Normally takes a few tries.
Three beers, or only two if they're pints.
Originally Posted by exshankerz
thanks guys sounds pretty easy to change the shocks... i will have a look at the tire pressure aswell i think they are around 32 i might let some air out
I wouldnt let air out. The specs are 32/33 I beleive (I could be backwards) but underinflating can cause uneven wear and some serious things could happen if you let out too much. Just leave it at factory specs and change the shocks.
The short wheelbase will result in a choppy ride, but it should not be rough (pounding). Unless you have a lot of miles, the oem shocks should be good. I can't tell any difference with 37k on mine. The low profile tires will definitely contribute to a firm ride since there is not much sidewall to soak up bumps.
Tire brand can make a huge difference...*True, that's why I go with Pilot Sports.* Aside from that, the Crossfire is simply a firm-riding car. If you think the Limited is bad, you should drive an SRT-6. The suspension in that car is as comfortable as falling down a staircase.
I noticed this for the first time today, some of the roads near my house aren't in the best shape. As I was driving, I noticed nearly every bump in the road and when i hit a small bump or dip on one side it seemed like the whole car wanted to jerk that way. I just assumed that this comes with the territory of owning a small sport's coupe.
nah it seems to be all stock, yeah the short wheel base does not help haha i was just wondering if anyone else had the same problem i thought mabye it was just me i have read a few reviews how they say the ride isnt that bad :? i guess i am driving alot on back roads in Australia (Not the best) im pretty sure i have put my back out now lol , but will suss out the shocks ect
I would play with the tire pressure too !!!! Made a big change in the way mine rode !!! I ended up with higher pressure in back for better ride !!!! Dont figure but it worked !!!!!
Kodebuster
Nov 5, 2020 04:06 PM
atdavis2
Sep 21, 2015 01:25 PM
ttosh
Jul 31, 2015 11:06 AM
