Rough idle at stop lights, sluggish at low RPM
I have a 2004 coupe automatic, every day driver. I just had 100,000 mile maintanance done at dealership. Now this idle problem. It is ready to die at red lights. Sluggish in the 1500 RPM area. Highway driving is ok. I did not have an issue before the service. The service guy cannot find anything, said it was fine. Well, it's not fine.
What should I tell them to check?
Could they have gapped the plugs incorrectly?
I'm not mechanically inclined.
Janice
Janice
It sounds like the crankshaft position sensor. Theres lots of threads here that talk about it as it is a common problem. Another quick thing you should do is make sure that your intake cover is on properly. It happened to me one time where I put it back on, but not all the way covering the hole and I started getting those symptoms. after I put it back on properly, the issues went away.
Mass air sensor probe, dirty fuel filter, EGR Valve, Throttle Body Cleaner, Crank shaft position sensor, intake cover.
Lot's to look into! Right?
Mine is doing the same thing and also throwin the po171 and po175 codes (lean) mine ran rough for a bit (weeks) before throwin the codes....Im doing my fuel filter again this weekend last did it at 50k...also gonna clean o2 sensors and maf sensor. 108K miles
Janice
Janice
Janice, What exactly did the 100K mile maintenance include??
You mention gapping of S.P........Did they replace the spark plugs......if so, they may have mixed up S.P. wires when re-installing??
Sounds like you may have a misfire condition.
I would also have them check for a vacuum leak and that the engine cover is on CORRECTLY and sealing...
The simple things usually confuse them......
northwest_crossfire
May 30, 2016 05:19 PM
axnguyen
Jul 21, 2015 11:41 AM
