Need help. Car wont start
Old Mar 14, 2012 | 08:57 PM
BobbyCaz's Avatar
Default Need help. Car wont start
Searched the forum and have gotten no answers to help
Like the title says. Car wont start. Starter wont even click. Drove the car everything was fine, parked in my driveway, woke up the next morning and nothing.
Remote opens and locks car and sets the alarm.
Turn key in ignition all lights come on, on dash
replaced the cam and crank position sensor ( with bosch parts)
New Battery.
relay board is like new. All soldered connections look great.
Turn key to start NOTHING. no click from starter.
I need help or this car is going to be a big paper weight in a couple of days..
Chrysler dealers here have no clue about the car, wouldn't trust them tgo change my oil. And the mercedes dealers i have talked to wont look at the car
Old Mar 14, 2012 | 09:02 PM
BobbyCaz's Avatar
Default Re: need help. Car wont start
Also picked up a ODB II scanner. An actron Model #CP9125. Connect it to the car. And it gives me back a message of........ NO LINK
Old Mar 14, 2012 | 09:09 PM
Did you turn the ignition 'ON'?
Old Mar 14, 2012 | 09:11 PM
Mrmiata's Avatar
I hope not! Otherwise this one doesn't sound good at all
Old Mar 14, 2012 | 09:18 PM
BobbyCaz's Avatar
I tried on and off. hooked it up to my dodge truck and it connected.
Use the following chart and check voltage at #16. And then ground on #4
If no battery voltage on #16, check the large fuses in front of the battery under the small square cover.
Old Mar 14, 2012 | 09:21 PM
BobbyCaz's Avatar
Going to do this now.
Old Mar 14, 2012 | 09:26 PM
If no power on 16 check this fuse for voltage.
Old Mar 14, 2012 | 09:40 PM
Using a volt meter, check and be sure that all terminals have battery voltage here:
especially fuse #4. This panel is located in front of the battery on the fender well, under a cover.
Old Mar 14, 2012 | 09:59 PM
BobbyCaz's Avatar
These fuses all have power
Old Mar 14, 2012 | 10:04 PM
BobbyCaz's Avatar
Just cut up the leads for my meter, got it in there and all is good
Old Mar 14, 2012 | 10:05 PM
BobbyCaz's Avatar
The scanner does power up. but tells me no link.
It appears you need a bit more diagnoses than I can help with, without being there. My next step would be to see if voltage is getting to the starter solenoid while someone turning the key for you. That way you can eliminate the starter being bad.
The 'no link' and no start have to have a common defect. Its just a matter of finding it.
Good luck with the repair, I will look around some more.
James
Old Mar 14, 2012 | 10:12 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
If you have a voltmeter please confirm the battery voltage.
Old Mar 14, 2012 | 10:14 PM
A last word...
I'm thinking you may have some type communication problems between modules. Could be external, internal. Check all your connections and plugs at the various modules. Here is a diagram that could help out.
Old Mar 14, 2012 | 10:15 PM
BobbyCaz's Avatar
Battery voltage is 12.2
Old Mar 14, 2012 | 10:18 PM
What year and how many miles for the car.
I'd do as was said and check the cable to the starter, maybe corroded inside the insulation, is there any corrosion around the battery area, good connections ?
Old Mar 14, 2012 | 10:22 PM
Battery voltage should be 12.6+. But at 12.2, you should still get a click or attempt.
Old Mar 14, 2012 | 10:24 PM
BobbyCaz's Avatar
2005 limited, Automatic, roughly 75,000. There was corrosion with the old battery cleaned terminals and all was good. new battery is only a few months old. I've removed and replaced the connections so many times, they are clean as i whistle.
Gonna have to check the starter cable and starter itself on Saturday. Don't have time to screw with it anymore tonight. haven't eaten dinner yet, and it's getting late
Old Mar 14, 2012 | 10:28 PM
mferreira3417's Avatar
i think i would ohms test the sci wire pin 32 20 gauge wire dg/yl of the powertrain control module c4 connector with pin 3 dg/yl at the diagnostic connector
make sure you have good continuity
make sure good ground also at diag connector and power at pin 16 at diag connector
