Car Alarm
Old Mar 27, 2012 | 11:35 AM
jayaurtherrank's Avatar
Default Car Alarm
Can Anybody Help Me? My 05 Crossfire Will Not Start, Every Time I Open The Car Door The Alarm Goes Off And The Car Will Not Start. The Remote Fobs Will Not Unlock The Door Or The Trunk And The Battery Seems Fine. I'm Am Out Of Work And Cannot Afford Expensive Repairs. Please I Need Help.. Many Thanks
Old Mar 27, 2012 | 12:10 PM
Default Re: Car Alarm
What makes you say the battery is fine? Do the lights work?
A simple and cheap test would be to disconnect the battery terminals, leave it for five minutes and reconnect after making the contacts, positive and negative clean and shiny. Also look at the ground wires.
Lift the carpet in the trunk and look down the back of the foam block in the trunk well, if you see water you have probably found your problem.
Inspect and report back, just believe we can solve this.
How old is the car, miles on it, model.
Old Apr 1, 2012 | 10:03 PM
Rockster's Avatar
I feel for you.
The most annoying sound I have ever heard is the Crossfire alarm. Which is perfect for what it was designed for :-)
Old Apr 4, 2012 | 06:34 PM
Goldwing's Avatar
You also have a computer problem. Every freaking word starts with a capital lettler.
Old Apr 4, 2012 | 07:12 PM
.........and you have a spelling problem, lettler? LOL Or should I say lottles of laughs?
Old Apr 4, 2012 | 07:59 PM
jmswllms's Avatar
Needs battery, Even if it checks good, Needs Battery
Old Apr 4, 2012 | 08:40 PM
If the battery checks out good with a proper load test then it should be OK.
As I stated earlier my money is on the security/air pump module in the trunk. The OP has not posted since and until he does, I say this thread is dead.
mhajek18
Dec 30, 2015 03:40 PM
autumnmass
Jul 2, 2015 10:35 PM
gobraves423
Jun 6, 2015 07:03 PM
Rwright2
Sep 18, 2003 04:55 PM
Iceman
Sep 15, 2003 07:14 PM
