XF Coupe front fogs
Old May 13, 2012 | 05:12 AM
GrantB's Avatar
Default XF Coupe front fogs
Are the front fogs UK car....an H7 bulb like the headlamps.... where are the bulbs changed from.... the wheel well hatch ??
I want to fit HIDs in these ???
Thanks in advance.
Grant B
Old May 13, 2012 | 07:03 AM
Default Re: XF Coupe front fogs
They are 9006 bulbs - can be accessed via the 2 little removable panels at the front of each wheel,
however, if you are fitting HID's, I would recommend you remove the wheel and the lower front wheel well panel one side at a time ( 4-5 10mm plastic nuts, one torx screw, #26 I think ).
You have to remove the belly pan to access the 2 lower 10mm nuts on each side.
( I took that opportunity to also remove the entire bumper cover so I could do some cleanup in the front area, not much harder, just a few more screws and nuts after removing the wheel panel. You do, however, have to raise both sides and support on jack stands .... )
If you do this - don't forget the temperature probe.
PNA
Nov 12, 2020 04:44 PM
Adrian_X
Nov 9, 2017 08:49 AM
tom2112
Jul 28, 2015 08:12 AM
TomSRT
Jul 21, 2015 06:50 PM
KwehCat
Jul 16, 2015 04:48 PM
