Replacing your coolant ?!
Old Aug 1, 2012 | 03:09 AM
Jackerman's Avatar
Default Replacing your coolant ?!
https://www.youtube.com/watch?v=t7Py...e_gdata_player
Anybody try this stuff , seems like it would work the way jay was talking about it
But then again he was using it in older generation cars
Old Aug 1, 2012 | 08:31 AM
6000rpm's Avatar
Default Re: Replacing your coolant ?!
Sure sounds like a good idea. Everyone's got aluminum engines these days. I wish I had all kinds of money like Jay Leno so I could try out all these ideas. $$$.
Old Aug 1, 2012 | 11:38 AM
Jackerman's Avatar
Is the engine in the xf made of aluminium?
Old Aug 3, 2012 | 01:46 AM
6000rpm's Avatar
Yes, the engine is aluminum.
Old Aug 7, 2012 | 06:34 AM
Black_X_Fire_04's Avatar
Nice find! Seems like a good idea. Even though Aluminum has a slow corrosion rate it still corrodes. How did you stumble upon the video? I was thinking of doing a flush soon. Maybe next maintenance. If I try the product I'lll post about it.
Old Aug 7, 2012 | 06:52 AM
I watched the video .......
Seems a good idea, but one statement in it threw me :
Jay says " use it on cars like the Corvair " ????????????
Since when did they change from air cooled ?
Old Aug 7, 2012 | 10:53 PM
Jackerman's Avatar
I'm subscribed to jays YouTube channel and that video was posted, I'm thinking about trying it my vw , but if you try it definitely post about it
Jay does restore cars , maybe his corvair has different cooling system ?
Old Aug 8, 2012 | 12:01 AM
The Beep's Avatar
It sounds like a new idea.
New idea's regarding engine maintanence scare me.
Our engines are designed to use a pressurized cooling system. What happens when you try running them without pressure?
Is the water pump going to circulate the coolant through the entire engine the same way and at the same rate?
My horrifically expensive engine with an intercooled supercharger isn't about to become the lab rat on this one.
Old Aug 8, 2012 | 12:20 AM
dtinker's Avatar
I think you still use a pressure cap, you do have to push out as much water/old coolant out of the system. It has a higher boiling point and freeze point. I could have got it wrong, But......?
Old Aug 8, 2012 | 06:12 AM
waldig's Avatar
Talking Re: Replacing your coolant ?!
Doing some reading and study, this is about 100% antifreeze and has LOWER specific heat (cooling capacity ). No thanks Woody
Old Aug 8, 2012 | 06:29 AM
I honestly do not think it would harm the engine. Now for under pressure, is the coolant pump not belt driven? That would be what circulates the fluid. The representative made a comment that you could open the cap while the engine was hot. I doubt they would engineer a fluid that is harmful to an engine. Most modern day cooling systems that run water/glycol are pressurized any ways are they not? Pressure is just a by product of the water mix in the system, is pressure really necessary, especially if there is a better fluid that does not create it? Good question for Evans. I am sure a quick call to their Corporate/R&D in Sharon, CT might have the answer!
Old Aug 8, 2012 | 09:11 PM
The Beep's Avatar
They engineered a coolant to sell and make a profit.
They're not going to have answers to your questions as they relate to our specific engines and superchargers.
If someone wants to dump the stuff in their SRT and drive 30K miles in southern Texas and come back with a positive report, then I'll consider it.
PNA
Nov 12, 2020 04:44 PM
Adrian_X
Apr 8, 2020 02:36 PM
sittininthesun
Aug 24, 2015 10:47 AM
Ralph289
Jul 26, 2015 12:52 PM
Tp'sfury
Jul 17, 2015 01:15 PM
