Resetting service odometer
Old Aug 12, 2012 | 08:54 AM
mrpeterman's Avatar
Default Resetting service odometer
Just did service on my car, does anyone know how to remove service settings?
Old Aug 12, 2012 | 08:57 AM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: Resetting service odometer
Its all right here : https://www.crossfireforum.org/forum...tml#post625895
Old Aug 13, 2012 | 08:40 PM
kurtisberry's Avatar
Good luck, and it takes some luck. Once I got it on the first try. Other times it has taken 50 tries over 2 weeks. I think it has a lot to do with how clean the switch contacts are. If it is hard to get the trip odometer to reset, it is impossible to get the service warning to reset. I found it helps to hold the switch in and rotate back and forth many times, dash dimmer rotation, just to clean the contacts a little before trying the service reset. Also makes the trip reset easier.
Old Aug 14, 2012 | 01:33 PM
Uncle_Al's Avatar
I have found that cursing helps.
Old Aug 14, 2012 | 01:45 PM
magneticred's Avatar
Make sure when you do the reset procedure that you turn the key to the on position, not the accessory position.
From the owner manual:
1. Turn key to the ON/RUN position.
2. Within one second press the reset button (22) twice.
3. The present status for days or distance is displayed.
Within 10 seconds turn the key to OFF/
LOCK.
4. Press and hold the reset button (22), while turning
the key to ON/RUN again. The present status for
days or distance is displayed once more. Continue
to hold the reset button(22).
After approximately 10 seconds, a signal sounds and
the display shows 7,000 miles (Canada: 11,000 km) for
approximately 10 seconds.
5. Release the reset button (22).
Old Aug 14, 2012 | 04:28 PM
I found it only works on the third Tuesday of each month when there is a full moon .....
Old Aug 15, 2012 | 07:24 PM
Did mine today on the first try. I was amazed.
1. Pushed and held the switch in while turning back and forth about ten time to clean the contacts.
2. Turn the key to on and waited about two seconds for the computer to boot.
3. Pushed the switch twice quickly. Service mileage popped up.
4. Turned the key off.
5. Held in the switch while turning the key back on and 7000 miles to go.
I think the key is to have clean contacts and hit it twice quickly, but not in the first second.
RED DOG
-C-I-C-C-I Discussion
Oct 8, 2015 09:28 AM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
Abaton6
Sep 24, 2015 10:14 PM
stelrz1
Sep 21, 2015 11:18 AM
MickeyNasty
Sep 6, 2015 08:29 PM
