30,000 miles. what needs servicing?
This is my first car, and so far I have done all repairs myself (would like to keep it that way)
So far, my 30,000 mile service list has:
-Oil change
-and maybe brakes pads (the front left is starting to squeak a bit)...
anything else to add to my list? Also, what are some good/low priced ceramic pads (anything without dust)?
-Oil change
PS: The rear pads are easiest, remove the wheel and just slide the top center pin out, take out the clip, and the pads slip out/in! After, put clip and pin back in
Great thanks! anything else you can think of? what about fluids? I have never checked my transmission fluid, nor do I know how to. What about coolant? etc.
you might want to replace the air filters and cabin air filter. ( also clean out the heater/AC fan, it loves to accumulate leaves and such )
I highly recommend the the Posi-Quiets. You have seen my wheels. I have about 1500 miles on the pads. I have never had to scrub the wheels since I had them put on. I hose them off, dry them(so there are no water spots), spray on a little CG P-40 detail spray and they stay clean and shined for weeks.
At 30K you are overdue for a brake fluid flush, and as other stated, I would do coolant as well.
The other things on the list, you do not have the mileage for, but definitely the age. Many here overlook the fact that not everything is mileage, a lot is age related as well. Now I am not telling anyone to swap out plugs on a 5K mile car, but at 30K and a potential of being up to 8 years old, I would think about it, as well as the fuel filter and differential.
How old is the car?
How old is the car?
Greg,
How old is the car?
How old is the car?
-Refering to what alaxfire stated, I could do and probably should do the air filters and fan cleaning.
-Now, when referring to brake flushes and coolant flushes, would those be things I would have to pay a shop to complete? Same question for the fuel filter.
-Is there a way I can check my spark plugs, to see if they are in good condition?
-Differential, you mean differential fluid change right?
Thanks in advance for putting up with my inadequate knowledge.
It really depends on what tools you have available to you. Brake fluid is a pretty easy deal if you have a helper, spark plugs are easy but certainly not due yet (maybe shoot for 50K which is still early). Fuel filter isn't due and as far as the diff goes, yes, that's what he's refering to, but 30k seems quite early. I'd go for 50K as long as you drive it frequently and then do plugs, fuel filter, A/T fluid and if you're feeling saucey, diff fluid. Air filters and cabin filter though are pretty simple and are due if they haven't been replaced.
If it is a car you plan on keeping, I would recommend you follow my advice, the plugs can probably wait, but the rest would be advisable. I have seen the diff fluid first hand from XFs ranging from about 30K, up to 60K and it is some nasty stuff either way, but usually less debris in the 30K mile fluid. My fuel filter at 45K was rusted to $hit, not exactly what I want my 93 octane fuel running through, its a $50 part, and takes a decent mechanic about 20 minutes to complete, you will need new hose clamps if the new one does not come with them...
He says no fuel filter or spark plugs, but based on age, our service guide seems to disagree, by a few years...
- Replace fuel filter and air cleaner filter element (60,000 miles or 4 years).
- Replace spark plugs. (1000,000 miles or 5 years).
- Replace engine coolant using extended life coolant (1000,000 miles or 5 years).
And I can attest to the cabin filter. The 3rd owner and at 101k miles, I don't think mine was ever changed until I did it today.
Boiler - what is the viscosity of the diff fluid? How hot does the rear end need to be to be easily drained?
John is right. I did my coolant at 60,000 and even that was kinda late. I'm doing fuel filter, plugs, diff and brake fluid as soon as I can - but it looks like I'm on business travel almost 100% until the week of the Fall Dragon... gonna be close to have it done before the fun.
We had no problems getting mine out and it was luke warm at best, we did not warm it up intentionally, but I have access to a nice pump with a fitting that does the diff very well. Not a difficult service at all, but makes all the difference in the world, when I did this car (at roughly 45K) it was almost as if I modded it because the power was more free to transfer....
Thanks for the great tips guys. I already bought a cabin filter, air filters, new posi quiet ceramic pads, and stuff for an oil change.
I still don't know enough to start buying fluids for coolant, diff. and brakes;
but I will probably get the fuel filter. (If I can find out which one to get)
Then when I go to the shop, to get the filter put in, I might just tell them to do the coolant, diff. and brakes as well.
For those of you who go to shops, do you usually buy the fluid and give it to the mechanic to use? Or do you just trust him to use the right stuff?
What about transmission? Should I do that too?
I might wait to do the plugs in a few months, when a few more pay checks come in.... This stuff adds up
Not trying to start anything, but how can you say that? He is looking for advice on what is recommended and his car is a 2006, which means it was more than likely produced in 2005, making it at least 7 years old. Clearly above, directly from the manual, it states 5 years for plugs. I understand there is some room to fudge, especially with low miles, but at least give the guy accurate info based on Mercedes engineers' data, not your opinion...
Thanks for all your imputs, Its all appreciated.
I know most of you have done all of this already, I was wondering what fluids , spark plugs, and fuel filters you guys used so I can start buying those too.
ATF: So far from searching around, a lot of people wanted shell ATF but its out of stock, and others use mobile one 1-75-140 or royal purple 75-140
Brake fluid: I saw it has to be DOT 4? and people use valvoline, or ATE super blu?
Differential: synthetic SAE 75W-85 axle lubricant? I have no idea what kind is good. I read many people having trouble finding lube in the right specs. Most people were finding lubes around 75W-90 or 75W-140.
Coolant: What color is your 50/50 Zerex G-05 and distilled water Alax? Mine is like a red or orange color.... I know OEM is supposed to be blue.
Fuel filter: looks like a Bosch/Mahle ?
Plugs: NGK Iridium IX Spark Plugs Part#BKR6EIX-11 ? one guy used bosch iridium 9600 but his car was going to ****, so I don't know about those.
Thanks again for all your guys' help/input!
