Air Pump Woes
Old Aug 28, 2012 | 12:18 AM
aphuntin's Avatar
Default Air Pump Woes
I installed my new Bosch Air pump for my XF 2004 and now when I start my car it idles very rough and my exhaust smells very gas rich, what gives?
Old Aug 28, 2012 | 07:16 AM
Default Re: Air Pump Woes
Air leak somewhere?
Old Aug 28, 2012 | 02:41 PM
aphuntin's Avatar
So I checked all the hoses etc couldn't find an air leak, unplugged the battery then plugged it back in and restarted the car. Now my CEL light is off but my BAS ESP light is on and its still running rough, so much so my engine is literally shaking in idle....
Old Aug 28, 2012 | 04:29 PM
Reset the BAS/ESP light by turnng the steering wheel all the way left then right it should reset the light. Thats a common fix for that. Are you sure you hooked up the air pump and everything right?
Old Aug 28, 2012 | 04:35 PM
aphuntin's Avatar
Well I will double check, I put the hose back in, the two prong cord and the ground wire to the bolt....thanks I will try that and see what happens
Old Aug 28, 2012 | 08:26 PM
aphuntin's Avatar
Thanks Graphite Ghost, apparently after I put the engine cover on I knocked an airline house off :/, and after doing what you mentioned with the ESP light it worked!! Thanks again!
Old Aug 29, 2012 | 01:35 PM
Wooohoooo Glad you got her running right again! Hey are you going to the Tail of the Dragon in October?
tritongreen
Sep 18, 2015 07:32 AM
RacerXofFL
Sep 15, 2015 05:00 PM
cppeabody
Sep 15, 2015 08:43 AM
81's
Sep 13, 2015 04:34 PM
crmnal
Sep 6, 2015 08:07 AM
