Getting new spark plugs? Which should i go for?
Old Sep 26, 2012 | 11:55 PM
JoshnoSRT6's Avatar
Default Getting new spark plugs? Which should i go for?
so i had my baby for almost a year now, and boy are these cars reliable as hell! I've had no major problems, but with the season now changing. I was thinking of doing stuff to keep it running good in the winter such as: tune up's, new air filters, cabin air filters, brake change (maybe new rotars), and a new set of winter tires. First off, I've been doing some research on the NGK Iridium IX Spark Plugs here on the forum, but if i were to get them wouldn't i need new spark plugs cables also? Or could i use the existing ones that i have on the engine? Also, What kind of tires would you recommend me that are good in the winter and/or that have good grip and tread life?
Thanks again!
Old Sep 27, 2012 | 12:33 AM
rcompart's Avatar
Default Re: Getting new spark plugs? Which should i go for?
Rob at NeedsWings is your friend. Plugs and wires are what I'd recommend if you're due. One or the other and you're just cheating. Get a set of stock heat range plugs unless you're going crazy with the power adders then go a heat range colder. Also look into a set of Magnacore wires. They're better wires and they cost about the same as OE replacements plus they'll add a little color to the engine compartment.
Old Sep 27, 2012 | 12:47 AM
JoshnoSRT6's Avatar
Hey thanks! Do you have any links to the wires?
Old Sep 27, 2012 | 12:53 AM
rcompart's Avatar
Plugs - NGK Laser Iridium Spark Plug Set, Stock Heat range
Wires - Magnecor KV85 8.5mm Competition Ignition Cables
It looks like he's running a sale so you can pick everything up for about $250 which is just a little more that what the wires alone would cost from the dealership.
Old Sep 27, 2012 | 01:00 AM
JoshnoSRT6's Avatar
Awesome! Thanks alot! from what i hear this will improve my performance
Old Sep 27, 2012 | 11:14 AM
deltacrossfirebob's Avatar
after reading about rob and needswings here i went to him.
told him what i was doing in mods now and asked for his advice.
bought his ngk plugs, which were a h... of alot cheaper than anywhere else and his wires.
mpg was up appx 10% and the get-up-and-go also.
have fun doing the job.
Valk
Jun 22, 2025 09:15 PM
Sterling57
Apr 11, 2016 06:11 PM
Sep 28, 2015 07:40 PM
atdavis2
Sep 21, 2015 01:25 PM
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
