2004 crossfire shut down
Old Oct 6, 2012 | 10:52 AM
mj24724's Avatar
Default 2004 crossfire shut down
i had the problem w/vehicle that shut down ,only to restart.i replaced fuel relay computer.does any one have a better fix.or understand the problem.i`m not getting computer code to send me in the right direction.thanks for anyones time.
Old Oct 6, 2012 | 11:39 AM
Default Re: 2004 crossfire shut down
Give all the symptoms and you will get help. Did the car turnover or not when it refused to start etc.
Also use smaller text, this is painful.
Old Oct 6, 2012 | 01:32 PM
mj24724's Avatar
no it didn`t turnover had power everywhere else all lights light up on dash when shut down.wait about 20 minutes it will start.i bought a new fuel relay component.it didn`t make a difference. i`m not sure but it happens after it gets hot.not to familier with problems that come up.don`t have the money to take it anywhere.
Old Oct 6, 2012 | 01:46 PM
robby363's Avatar
It might be the crank position sensor.
Old Oct 6, 2012 | 01:50 PM
You say fuel relay component, do you mean Relay Control Module?
As normally I would say the RCM is the culprit.
See this thread;
https://www.crossfireforum.org/forum...tml#post430634
Old Oct 6, 2012 | 03:36 PM
mj24724's Avatar
i just ran computer on car got two codes,p0161 a heat sensor,and p0335 crankshaft position sensor.i`m guessing its the crankshaft position sensor?
Old Oct 6, 2012 | 03:43 PM
most likely
Old Oct 6, 2012 | 03:47 PM
mj24724's Avatar
now i guess i need some help finding and changing out crankshaft position sensor.some guidance to a location or pic would help.
Old Oct 6, 2012 | 07:35 PM
PNA's Avatar
PNA
Use the search to get the info. There is a thread / sticky with info on where it is and how to replace it. It's about a $50 part and about 20 minute repair.
I believe this is one of the key threads. Instructions and pictures are included.
https://www.crossfireforum.org/forum...on-sensor.html
Old Oct 24, 2012 | 01:43 PM
mj24724's Avatar
come to find out that the plug for cps was extermely lose tightened pins works fine now
Old Jun 7, 2013 | 08:14 PM
wellywellet's Avatar
I just had this problem, changing the throttle position sensor didn't solve the problem, it is when I touched the TPS lead or connector and engine immediately shutdown, I solved the problem by closing gap between tabs connector to ensure good contact with TPS pins. Now engine run fine whitout uncommand shutdown.
victorlautreamont
Jun 29, 2017 01:22 AM
ultrajim49
17
Jun 27, 2015 12:20 AM
XfireAsh
Jun 22, 2015 11:19 AM
adamlevy
Jun 7, 2015 08:13 PM
texex91
Jan 21, 2009 06:54 PM
