Dampness in headlight unit
Old Oct 14, 2012 | 10:21 PM
Centaurv's Avatar
Default Dampness in headlight unit
I have noticed that dampness has formed on the internal side of my passenger side headlamp unit. This is on a 2004 coupe, but it could have happened on any year or Xfire model. Does anyone have ever exprerienced this and what might be the solution to the problem.
Old Oct 14, 2012 | 10:57 PM
Default Re: Dampness in headlight unit
Did this happen suddenly or take some time?
Old Oct 14, 2012 | 11:17 PM
turbomar's Avatar
You can remove one headlight bulb and use a hair dryer. Take extra care not to loose the bulb retainer spring
Old Oct 15, 2012 | 08:44 AM
Yea, you can do that, BUT ! It's gonna leave water spots on the inside surface.
( HINT, also remove the eyebrow light socket to allow the air blown in someplace to exit ... )
IMHO, you should just remove the unit and follow maxchicon's instructions for removing moisture .....
https://www.crossfireforum.org/forum...ighlight=99%25
Old Oct 15, 2012 | 10:15 AM
Drying and cleaning it does not stop it from re-occurring.The cause of this has to be found to prevent it from happening again. The kit that is supposed to prevent this may or may not work in this case.
Info from the OP is required.
Old Oct 15, 2012 | 10:35 AM
Good point ......
Old Oct 15, 2012 | 10:02 PM
Centaurv's Avatar
I could not say, I know I noticed it when I wash the car last week-end, and it was not the case 2 weeks earlier
Old Oct 15, 2012 | 10:12 PM
Centaurv's Avatar
Alaxfire, Thank you for the info
smfrycruzr
Jul 17, 2023 05:33 PM
Sterling57
Apr 11, 2016 06:11 PM
TOPLESS
Feb 9, 2016 11:28 AM
TOPLESS
Jan 15, 2016 12:39 PM
smokey847
Sep 15, 2015 10:47 AM
