TPS reads 50 % open
Old Dec 4, 2012 | 02:21 PM
robbie's Avatar
Default TPS reads 50 % open
[After about 20 miles on driving my 2005 srt6 I have a lost of accelleration. I hooked a scanner and I can see that when the loss accures my TPS % is reading 54 % at wide open throttle. Normally it reads 99.7 % . Any one had this problem. Robbie
Old Jul 3, 2013 | 06:27 PM
Bill F's Avatar
Default Re: TPS reads 50 % open
Have you tried a throttle reset?
Old Jul 3, 2013 | 09:30 PM
Bigkid's Avatar
Sounds like you may have a bad intercooler pump which is a common problem with the SRT 6. Does this occur only after your car is warmed up? Does the throttle responce return as the engine cools down some?
If so it is probably the IC pump. Not a costly fix.
If you have a way to monitor the IAT's you can see if they spike and you lose power. Good luck.
Old Jul 3, 2013 | 10:00 PM
grip grip's Avatar
+1 Likely a bad intercooler pump. A $100 DIY fix if you have tools and a little time.
Old Jul 6, 2013 | 01:20 PM
robbie's Avatar
THe problem was the coolant pump for the supercharger. Robbie
Mackel
Oct 16, 2015 09:03 AM
Ralph289
Sep 21, 2015 09:34 PM
81's
Sep 13, 2015 04:34 PM
Ed Mahoney
Sep 8, 2015 08:36 AM
williammt
Sep 6, 2015 11:23 AM
