Stereo system problem
Old Jan 20, 2013 | 05:44 PM
GrantB's Avatar
Default Stereo system problem
Gents, another little problem I've been victim to...
The music god hates me I think....
Some times when I power up the stereo unit - by a single push on the volume button, the display
will simply read CHRYSLER ..... and the devise in none functional...
tried loading and removing CD's and turning on/off many times, switching off the ignition and on again....
then when it's got the better of me, I will try a few days later and it works perfectly, for weeks, then quits again without warning.
It never fails during playing music, only on power up initially....
Any clues ???
Cheers
Grant B
Old Jan 20, 2013 | 10:36 PM
Mongoose57's Avatar
Default Re: Stereo system problem
Hi I had the same issue when I first got my 06 limited after pulling and cleaning the radio fuse and the sub fuse twice I have not had the issue since
Hope this helps
Cheers
Mongoose57
Old Jan 21, 2013 | 02:28 AM
GrantB's Avatar
Default
Many thanks Mongoose.
I will do this today and let you know what happens.
Cheers.
Grant B
Mongoose57;719785]Hi I had the same issue when I first got my 06 limited after pulling and cleaning the radio fuse and the sub fuse twice I have not had the issue since
Hope this helps
Cheers
Mongoose57[/QUOTE]
Old Jan 21, 2013 | 06:41 AM
xfchris's Avatar
...i never actually turn my radio off by the unit itself... it comes on and goes off with the ignition switch...or am i missing something...
Old Jan 21, 2013 | 10:16 AM
user 8202's Avatar
Banned
In addition, you might want to clean the multipin connector using electronic contact cleaner. Oxidation on electronic connectors (unless they are gold contacts) is common over time. Contact cleaner comes in an aerosol can and can be purchased from Radio Shack/The Source.
Old Jan 21, 2013 | 07:58 PM
Mongoose57's Avatar
Good advice on cleaning the pin connector,that probably would have been my next step. I should have pointed out that in my case I could not even get the Crossfire logo to come up when I turned on the head unit by pushing in on the left main control button. But the symptoms were just as you described
Good luck
Cheers
Mongoose57
Old Jan 31, 2013 | 09:56 AM
loumas53Yahoo.com's Avatar
I have the same problem occasionally. It seems to work if I turn the engine off & wait 15 minutes. Where is the radio sub fuse? I want to try that.
Bob
Old Jan 31, 2013 | 10:05 AM
Bob
On the back of the radio.
Old Jan 31, 2013 | 12:27 PM
Mongoose57's Avatar
My bad, when I said I pulled the sub fuse I should have said I pulled the sound booster ( amp ) fuse located in cir# 23 in the underhood fuse block. My radio fuse's are listed as cir# 5 & 8 (coupe ) roadster is listed as cir#30. Also listed is cir#35 for radio frequency remote control,hazard warning flasher .....
This info is from the 06 owners manual sorry for the confusion.
Cheers
Mongoose57
Old Feb 1, 2013 | 01:42 PM
Ed Mahoney's Avatar
mine has done the same thing before too !!!! but has always come back on after I shut the car off then turn radio back on !!!! has done this about 3 times now in the last 2 yrs ?????
Old Mar 12, 2013 | 05:39 PM
I tried cleaning the radio fuses listed in the manual. I used a toothbrush on the fuses and sprayed the empty fuse connectors in the fuse box with a cleaner. It still does not work 5% of the time. It will work if I shut the engine off, remove the key, reinsert and turn the ignition back on.
Bob
jhansen
21
Feb 15, 2017 04:26 PM
Ralph289
Jul 26, 2015 12:52 PM
gtjl
17
Jul 22, 2015 06:28 PM
ja.nko
Jul 10, 2015 03:21 PM
Sussudio
Jul 3, 2015 10:56 PM
