jack stand placement
Old Mar 22, 2013 | 03:28 PM
bieber's Avatar
Default jack stand placement
I am getting all four wheels off the ground for the first time soon to change all the brakes & the steering stabilizer. The four jacking points are obvious, but what about jack stand placement?
The maintenance manual says:
FLOOR JACK: When properly positioned, a floor jack can be used to liftthe vehicle. Support the vehicle in the raised position with jack stands at thefront and rear ends of the frame rails.
Do I just find a suitable place on the "ends" like the book says or does anybody have a recommendation?
Old Mar 22, 2013 | 03:37 PM
sk8erjosh09's Avatar
Default Re: jack stand placement
Differential for the back, and crossmember under the motor for the front. Jack stands under the 2 "tabs" that are on each side of the vehicle.
Old Mar 22, 2013 | 07:53 PM
bieber's Avatar
"Differential for the back, and crossmember under the motor for the front. Jack stands under the 2 "tabs" that are on each side of the vehicle."
sk8erjosh09 (thanks for the help!),
You are saying jack the car up from the front crossmember and differntial and place the jack stands under the four factory "jack points" (plastic blocks) on each side between the wheels?
Old Mar 25, 2013 | 10:33 AM
Sorry for my late reply (crazy weekend)... but yes exactly.
Mackel
Oct 16, 2015 09:03 AM
ritous1
Sep 26, 2015 01:27 PM
Jackobo
Sep 24, 2015 10:21 PM
velociabstract
Aug 7, 2015 01:30 PM
smfrycruzr
Jul 5, 2015 11:42 PM
