How do I Adjust the clutch HELP
Old Apr 6, 2013 | 11:57 AM
Crossfire725's Avatar
Default How do I Adjust the clutch HELP
When I have the clutch to the floor at a roll and I shift into gears with still holding the clutch in, you can hear a noise that sounds like its slightly engaging but not totally, I can't explain it like you can feel resistance while shifting on a roll between gears. So I figured it may need adjusting? I have 93k on a 04 6 speed. Thank you ahead of time
Old Apr 6, 2013 | 12:51 PM
+fireamx's Avatar
Default Re: How do I Adjust the clutch HELP
syncronizer - Yahoo! Search Results=
Old Apr 6, 2013 | 01:36 PM
MoparFreak69's Avatar
The crossfire clutch is hydraulic so there is no adjustment possible. Sounds like your pilot bearing is hanging slightly causing the input shaft to still spin. Only fix is to pull the trans. Might as well do a clutch kit while you are in there.
maxcichon
Apr 21, 2021 08:29 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
atdavis2
Sep 21, 2015 01:25 PM
waldig
Aug 24, 2015 10:40 PM
ricardo 53
Jul 21, 2015 07:49 AM
