Need help mechanical problems
Old Apr 22, 2013 | 12:48 PM
psuperti's Avatar
Default Need help mechanical problems
I almost didn't make back to the house. I had the crankshaft sensor and mystery no start previously, however this feel different. One month ago it did the same thing Chrysler said it was loose coils and misfires. Here are symptoms, driving along normally suddenly the throttle does not accelerate, I can maintain 15 mph tops, the engine sounds reved up, the check engine line only came on last month but not this time around. Usually to fix it I pull over turn the car off and back on. This time it would not, so I disconnected the battery, put the terminal back on and it temporally fixed it. Still no check engine light to get codes. My appointment is for the 6th of may at the dealership. I drove 700 miles since Chrysler fixed the loose coils and misfire codes. I have a Nitrous tuned ECU that I can put on if it drives well than its a ECU problem on the stock ECU that came with the car. Any thoughts???
Old Apr 23, 2013 | 12:09 AM
Selbyl's Avatar
Default Re: Need help mechanical problems
take a look at the toy in my signature. This can pull up codes even if the engine light isn't on. I've had a few issues with my MAF causing some stuff to pop up even though my engine light has never come on. Also shows pending codes as well. Hope this helps a bit.
Thanks for emailing me back a few months ago when I had that nitrous question. Hope all is well.
Old Apr 23, 2013 | 11:56 AM
psuperti's Avatar
Welcome, thx for the suggestion. I'm definely not the same when I"m sad about the crossfire.
Old May 6, 2013 | 04:16 PM
psuperti's Avatar
Ok the car went into the dealership today. They said the problem is a Non Responsive Throttle body. I have the TVT larger throttle body from that older Mercedes. I also have a Sprint Boster. You think their right? They said a new one is $1700. Any other routes for obtaining a used one? Thanks please let me know
Old May 6, 2013 | 04:39 PM
Mrmiata's Avatar
You can find them on Ebay.. that and several members have good 68mm stashed away if your desperate to get going.. Also there is a car parts online that a lot of users seem to buy from.. search 74mm should bring them up..
Old May 6, 2013 | 05:46 PM
Car-Part.com--Used Auto Parts Market
make sure the part # is 113-141-01-25 if you want the 74mm.
Old May 6, 2013 | 05:49 PM
Mrmiata's Avatar
There you are! Just when we needed you most..
By the way.. what's your commission rate up to now?
Old May 6, 2013 | 05:53 PM
psuperti's Avatar
Thx guys hope its a Sprint Bosster failure, not the TB or Throttle pedal. I got my TB from TVT last time. Does the 74mm work without any modifications?
Old May 6, 2013 | 05:55 PM
Mrmiata's Avatar
From what I've read in that old thread.. that is exactly what you already have in place..
Just make sure you get the MB number alaxfire posted!
Old May 6, 2013 | 06:02 PM
I wish ......
Old May 6, 2013 | 06:03 PM
Yes, the 74mm will work with or without a new tune.
Just do a throttle reset, or disconnect the negative battery lead for 15 minutes and let it re-learn itself.
Old May 6, 2013 | 07:08 PM
psuperti's Avatar
Nice! Thx for the quick response
Old May 6, 2013 | 07:10 PM
Mrmiata's Avatar
If your in Tulsa area I could meet you with a 68mm (plug and play) to makes sure about it being a throttle body issue...
Old May 6, 2013 | 07:12 PM
psuperti's Avatar
I'm in Colorado springs Co, wishing that I didn't sell my 68mm Tb lol
Old May 6, 2013 | 08:21 PM
Mrmiata's Avatar
Yeah, I figure it won't hurt to have a spare part or two around..
Old May 6, 2013 | 08:55 PM
Selbyl's Avatar
I have my spare 68mm throttle body. Would love to help out a fellow military member. Shoot me a PM.
Old May 7, 2013 | 11:26 AM
psuperti's Avatar
Cool! the dealer will try the other ECU and Sprint Booster removal today
Old May 8, 2013 | 02:48 PM
psuperti's Avatar
The car is working again. I made the dealership try my racing ECU and no driving problems so far 25 miles. I'm glad I did not have to buy a part and they only charged $46 for the issue. However I'm out a ECU (tuned by UPSOLUTE in 2006) I figure if that truly was the problem I lost $2000 by having a flashed ECU go bad. Super
Old May 8, 2013 | 09:12 PM
itsky's Avatar
Glad that you have it all working. If you are up for it this weekend, us Colorado Crossfire owners are having a maintenance/part upgrade day. You are welcome to join.
Old May 9, 2013 | 09:47 AM
rmaier's Avatar
That ECU problem seems very strange to me. Bring it up here for the shop day on Saturday and we can check it out maybe just loose connections and the dealership just replaced the whole thing without really diagnosing the issue. Anyway would like to meet you so come on up like Evan said and we can look into it. Maybe you don't have a bad ecu. I have not heard of anyone needing to replace 1 before they are pretty reliable and I have swapped out mine and some others regularly with no issues.
Robert
