Low Idle
Old Jun 27, 2013 | 11:30 PM
Hyperman's Avatar
Default Low Idle
I have had my 2004 coupe with auto trans for 3 years now. I continue to have an issue with low idle. When I first start the car it idles at 700rpm. After it warms up, it drops to 500 rpm and feels like it will stall at stop lights. It never does stall. Is this normal? I have had my mechanic check for vacuum leaks and none found. I have also done the following over the past 3 summers:
New : spark plugs, fuel filter, air filter, crankshaft position sensor, MAF cleaned, throttle body cleaned, no engine codes, new battery.
Any suggestions or is this idle normal?
Thanks
Old Jun 28, 2013 | 07:20 PM
Default Re: Low Idle
Thanks
Is that 500 in drive?
I think mine is a little above that, maybe 600 in D.
Old Jun 28, 2013 | 07:27 PM
Hyperman's Avatar
yes 500 in drive. It makes the car shake when it idles that low. Feels like it is going to stall but never does. Does your car feel that way?
Old Jun 28, 2013 | 08:09 PM
MoparFreak69's Avatar
Mine idles at ~500 all day long. My car is a 6 speed though, so its going to be able to idle lower than an auto trans car. I don't know what autos are supposed to idle at. Does it mention anything on the emissions tag under the hood?
Old Jun 28, 2013 | 08:39 PM
Hyperman's Avatar
Is it a smooth idle or rough? The main issue for me is that it is a rough idle
Old Jun 28, 2013 | 09:38 PM
itsky's Avatar
Have you had any tunes installed? Is that with the A/C on?
Old Jun 28, 2013 | 09:42 PM
Hyperman's Avatar
A/C on, but it is almost exactly the same with it off. I apologize, what do you mean by tunes?
Old Jun 28, 2013 | 10:08 PM
itsky's Avatar
Car tuned by Eurocharged or another vendor (for more HP). I have noticed that my idle RPMs are a little bit lower while in D after the tune.
Old Jun 28, 2013 | 10:36 PM
Its relatively smooth. I can feel a slight hiccup every now and then, but otherwise quite smooth.
Old Jul 5, 2013 | 07:37 PM
RL67037's Avatar
Default
Finally took note on mine today and after warm up, A/C on, in drive, idle is at the first full line above zero on the tach which I think is 500 RPM - but idle is very smooth.
Old Jul 6, 2013 | 01:08 PM
SNAKEWOLF's Avatar
Maybe it is motor or trans mount wore out.
Old Oct 20, 2025 | 12:08 PM
Mistergee's Avatar
My 2005 roadster has the same problem with low idle when I start the car the idle is 750. Once I put it indri either drops to 550. Some times at a light the car will stall. I had all the plugs,wire and filters changed and still have the problem. WHY????
Old Oct 20, 2025 | 04:54 PM
Have you checked for a vacuum leak?
rampntlion
21
Feb 11, 2019 08:18 AM
Darryl Camisa
Oct 7, 2015 07:10 AM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
blackpepper
Racing
16
Sep 27, 2015 01:38 AM
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
