Irregular A/C blower speeds?
Old Oct 16, 2013 | 02:27 AM
darrman's Avatar
Default Irregular A/C blower speeds?
I have had my 04 Crossfire for a couple months now, and have only had to fix a couple things, (sticky key and ac filter) everything seems fine except for a strange problem with the fan speed adjustment.
Every once in awhile, as I adjust the speed, the blower will speed up or slow down on its own, as in today while sitting in the drive thru I brought it down from position 2 to 1 but the blower started blowing full blast for a few seconds then acted normal. It does this from time to time, turning it up or down causes it, and the blower can be faster or slower than intended.
So I am guessing a voltage regulator might be to blame, but I don't know enough about this car yet to diagnose it.
Any thoughts on what is causing this problem?
Thanks!
Old Oct 16, 2013 | 07:33 AM
Default Re: Irregular A/C blower speeds?
Either the blower resistor module on the blower itself, or a flakey control module assembly.
Old Oct 18, 2013 | 03:39 AM
darrman's Avatar
Thanks, any way to narrow down to just one?
Old Oct 18, 2013 | 08:27 AM
awdspyder98's Avatar
Mines doing the exact same thing. Subscribed!
Old Oct 18, 2013 | 08:54 AM
syfi's Avatar
See if these post helps...
https://www.crossfireforum.org/forum...tml#post748441
https://www.crossfireforum.org/forum...placement.html
syfi
Mar 28, 2026 04:14 PM
Valk
Jul 12, 2021 09:49 PM
rmcdaniel12
Nov 4, 2015 04:08 PM
jimf
Oct 10, 2015 10:22 AM
BEATv1
Sep 10, 2015 12:58 PM
