Signal Light
Old Nov 29, 2013 | 03:53 PM
cg80's Avatar
Default Signal Light
My left right signal is not working...changed bulbs...sanded contact points...still not working...rear light working??? any ideas or suggestions. Thanks Carl
Old Dec 2, 2013 | 11:31 AM
Ed Mahoney's Avatar
Default Re: Signal Light
did ya check the new bulb ? Is it good ? Never know these days about quality !!!
Old Dec 2, 2013 | 12:11 PM
Are the contacts touching?
Is there any voltage to be found at the contacts?
Simple questions, simple to check.
Old Dec 2, 2013 | 09:47 PM
cg80's Avatar
Got 3 bulbs...all work in the right side, none in the left side...will check current supply ...Thanks for your input..Carl
Old Dec 3, 2013 | 08:17 PM
cg80's Avatar
Solved the "front signal light not working"...This was accomplished with the help of some very nice Crossfire owners. Thanks all!!
Solution: Took a small screwdriver and spread the contact points on the male bulb holder just a tad...this caused the contacts on each unit to make a workable "contact" I understand this is a common problem... working great...Carl
PNA
Nov 12, 2020 04:44 PM
pioneer4x4
Aug 1, 2018 09:58 AM
KwehCat
Jul 16, 2015 04:48 PM
Adrian_X
Jul 12, 2015 11:05 PM
joethejeweler
Jul 7, 2015 08:58 PM
