Resetting the oil change mileage
Old Feb 27, 2014 | 06:03 PM
Stampede77's Avatar
Default Resetting the oil change mileage
I bought the car and just changed the oil for the first time and I can not reset the FFS that says I'm over my mileage
Any thoughts
I followed the steps in the owners manual with no success
Old Feb 27, 2014 | 08:39 PM
Default Re: Resetting the oil change mileage
It will work but sometimes it takes a couple of tries
RESETTING THE FSS MAINTENANCE INDICATOR AFTER AN OIL CHANGE
1) Move the ignition switch to the “RUN” position
2) Within 4 seconds of moving the ignition switch into the “RUN” position, press the reset button for the trip odometer
twice within one second
The display for the FSS service request is activated for 10 seconds
3) During the 10 seconds the FSS service request is displayed, move the ignition switch to the “OFF” position
The FSS service request will continue to be displayed
4) Press the reset button for the trip odometer and hold
5) Move the ignition switch to the “RUN” position
6) Continue to press and hold the reset button for the trip odometer (about 10 seconds) until the audible signal
sounds and the new start distance appears in the display
The tool symbol should disappear at this time
Old Feb 27, 2014 | 09:43 PM
Ottawa John's Avatar
As above - and you've gotta be quick! Be within the few seconds given and it will work. If it doesn't, keep following the instructions until it does.
Old Feb 28, 2014 | 07:09 AM
Also that reset switch is seldom used and can get dirty, after many tries you should eventually succeed !!!
Old Mar 18, 2014 | 06:29 AM
Ed Mahoney's Avatar
make sure you follow the manual & do all the steps in a row & do them fast !!! I did it once the 1st time most of the time two or three tries !!!
Old Jun 30, 2014 | 11:11 PM
Moltenburn's Avatar
Thanks gents just took care of this. Got it on 2nd try.
xfClifford
Mar 3, 2021 04:52 PM
PNA
Nov 12, 2020 04:44 PM
sittininthesun
Aug 24, 2015 10:47 AM
xfClifford
Aug 3, 2015 11:03 PM
skeet370
Jul 18, 2015 01:02 PM
