Air conditioning/engine fan on for no reason
Old Jun 1, 2014 | 12:40 PM
samo59's Avatar
Default Air conditioning/engine fan on for no reason
The title says it all, my air conditioning is on blowing low and I have it set to off and the engine fan is on as well, also on low whenever I drive. What could be the problem? No problem codes are triggered
Old Jun 1, 2014 | 09:48 PM
Default Re: Air conditioning/engine fan on for no reason
Maybe >> Blower motor resistor
Old Jun 2, 2014 | 05:27 PM
samo59's Avatar
Would a bad FCM trigger a code? I don't want to order the blower motor resistor just yet as that seems like it's just an AC problem. My engine fan is also stuck on low besides the AC being stuck on low as well, not sure if the two are correlated. My "Low Coolant" indicator light is on as well but that is because I think I broke the sensor attached to the bottom of the coolant reservoir when I yanked it out to change the headlights, there is plenty of coolant in the reservoir.
Old Jun 2, 2014 | 05:34 PM
You say the AC is on do you mean the actual compressor under the hood? Or do you mean the fan which has the **** on the dash?
If it is the AC compressor maybe it is the button with the snow flake symbol on it.
If the AC compressor is actually on then the fan behind the radiator should be on as well.
Old Jun 2, 2014 | 10:45 PM
samo59's Avatar
The fan behind the radiator is on as well as the air conditioning WITHOUT the snow flake button on. Its blowing cold air as if the AC is set to low but everything regarding the AC is turned off.
Old Jun 2, 2014 | 11:10 PM
Is the compressor turning? I guess it has to be but ....
If it is I guess the snowflake button is bad or the wires are shorting out somewhere.
Old Jun 3, 2014 | 12:22 AM
samo59's Avatar
Yea pretty sure it is, the AC and heat both work fine when I turn the *****. If its an electrical problem with just the AC/Heat, what I don't understand is why is the engine fan on?
Old Jun 3, 2014 | 07:33 AM
Hate to say it, but my money's on a bad A/C Heater Control Module ( the silver panel with all the ***** and buttons for climate )
( it talks to the BCM and tells it to run the engine fan when you press the snowflake )
Here's one for a SLK32 ( it will work ) for only $89 with free shipping : ( it's not silver, but I have seen pictures here where some members have installed it )
97 98 99 00 01 02 Mercedes SLK230 Temperature Climate Heater A C Control Unit | eBay
NOTE: There are hundreds of the silver Crossfire ones available on car-part.com, some as low as $40.
Search for "Heater/AC Control"
Old Jun 3, 2014 | 03:01 PM
cobraken's Avatar
Is your switch on defrost? If so, compressor will run.
Old Jun 4, 2014 | 01:25 AM
samo59's Avatar
Cobra, I've switched the switch to multiple positions and it still blows air whether its on defrost or not. I'd hate to replace that whole panel, I'm putting the car up for sale soon (I'm moving out of state) and this most definitely won't help me sell it
MK2005
Nov 12, 2015 11:11 AM
RiderJC
Sep 7, 2015 11:19 PM
rdougc
Sep 5, 2015 10:30 PM
sk8erjosh09
Sep 4, 2015 09:24 PM
waldig
Sep 2, 2015 11:02 AM
