The Crossfire whistles when I put in Drive.
Old Dec 26, 2004 | 10:35 PM
Paul V's Avatar
Cool The Crossfire whistles when I put in Drive.
Is this a cold weather issue?
The Crossfire makes a whistling sound when I put the
Auto-Stick into "Drive" and accelerate 0-25+ mph.
The sound disappears after 20-30 minutes.
Please advise,
Paul V
Black Coupe 2004
Auto-Stick
Old Dec 27, 2004 | 12:33 AM
Bob G's Avatar
Default Re: The Crossfire whistles when I put in Drive.
Paul V
The only thing that I can see is if it is a whining or singing sound when cold it would probably be the intermediate bearing on the drive shaft.
however:
The halfshafts, differential and pinion bearings can all produce the noise. Try driving under load and if the noise appears it is probably the rear pinion bearing. If it whines during coasting, it is more than likely the front pinion bearing. Good luck!
PS: let us know what happens.
Old Dec 27, 2004 | 08:45 AM
mjanowich's Avatar
It could be the fans. Whenever I start it up in the morning, I hear a high pitched whine, which I think are fans, maybe part of the radiator system? Anyway, I think it's normal.
Old Dec 27, 2004 | 09:48 AM
NJspeed69's Avatar
It's not the fans since he only hears it when the car is put into drive. Fans either go on with the car, or some cars don't even turn the fans on until the engine is heated up and needs some cooling.
Old Dec 27, 2004 | 12:50 PM
bmerfan's Avatar
Guys.... I had the same problem and they replaced a belt / motor in the engine bay, no idea what it was but it was replaced under warranty.. now no more noise on cold startups.
Old Dec 27, 2004 | 01:51 PM
Bob G's Avatar
That would be great if you get off with just a belt, we'll cross our fingers for that one.
Old Dec 28, 2004 | 11:25 PM
AlvinByars's Avatar
Interesting ... mine whistles when my wife walks by ... but I think I understand why.
vspuds
Oct 11, 2018 05:16 PM
MJPowers
Jun 8, 2015 02:34 AM
JEFASOLD
Jun 5, 2015 09:04 PM
WindRestrictor
Jun 1, 2015 02:31 PM
bhd812
Nov 3, 2003 08:42 AM
