I need some better exhaust hangers, need help!
Old Oct 20, 2014 | 06:31 PM
elaus's Avatar
Default I need some better exhaust hangers, need help!
Okay so my exhaust system has been wiggling around a lot lately due to the fact that the rubber O-Ring hangers i have to hold the exhaust up keep falling off or breaking. Are there any metal hangers around? Ive been to a Meineke shop 3 times and each time they couldn’t figure out a way to properly hang the exhaust, they keep putting on rubber hangers that keep on breaking, they just can’t support the exhaust. Im thinking some maybe metal ones or something would do the trick, any one else have this problem? Any help would be appreciated.
Old Oct 20, 2014 | 07:37 PM
Default Re: I need some better exhaust hangers, need help!
Is this an OEM exhaust ? If so, you can get the OEM hanger donuts from Rob at Needswings, there should be no issue with them coming off.
If it is aftermarket cat-back, then there has been some mention on the forum that the hangers don't have enough curve in them, I think this is in regards to the MagnaFlow.
I replaced my OEM with an OBX Racing cat-back and have no problems with the hangers.
The OBX is basically build just like the Borla cat-back.
Old Oct 20, 2014 | 08:04 PM
velociabstract's Avatar
I have the OEM hangers but can't get them on. So .... big admission here, I used some rope. I have to change it occasionally because it burns through after a year or so.
Les
Old Oct 20, 2014 | 08:28 PM
dinasrt's Avatar
Les
LOL Les. Since you went first; here's my admission. I've been using wide(3/8") H.V.A.C. zip ties(in black for disguise) cinched down real snug, and it works real well. They seem to be able to handle the heat great. I use a set of extra long needle nose pliers and pull the ties up to where it looks and feels right, then reach in with side cutters or utility knife to cut the tails off.
Old Oct 20, 2014 | 09:39 PM
Mrmiata's Avatar
Cant we just get back to the basics.. ?
Old Oct 20, 2014 | 09:48 PM
Indelibility's Avatar
Lube is your friend, lol
Old Oct 20, 2014 | 11:03 PM
dinasrt's Avatar
Don't forget; We're not all from Oklahoma.
Old Oct 21, 2014 | 06:56 AM
Gee, you Okies are high tech, here in 'Bama we just use these :
TerryR
Dec 13, 2019 03:27 PM
cuziamninja
Oct 5, 2015 10:39 AM
Sep 28, 2015 07:40 PM
Big_Country
Sep 22, 2015 03:47 PM
RiderJC
Sep 7, 2015 11:19 PM
