Air Selector Dial Not Working
Old Nov 18, 2014 | 08:37 AM
eagle670's Avatar
Default Air Selector Dial Not Working
I have no heat blowing onto the floor board and the air selector switch does not have any effect on the air flow. I have heat blowing through all openings except the floor. Any ideas!
Old Nov 18, 2014 | 02:07 PM
maxcichon's Avatar
Default Re: Air Selector Dial Not Working
That's kinda' normal. You have to close the dash vents to direct flow to your feet.
The Euro way.
Old Nov 18, 2014 | 02:09 PM
eagle670's Avatar
But even when I do that there is no flow to the floorboards. No matter where I turn the dial, the air flow stays the same and blows through the dash vents and defroster. Something has to be wrong.
Old Nov 19, 2014 | 07:35 PM
maxcichon's Avatar
It's pretty cold here and I used the floor vent just this morning. Closing the dash vents forces air to blow out-at the side of my calf. Not where I have it blowing in any other car I've owned. If it doesn't do this, there is a problem elsewhere.
Sorry, bud.
Old Nov 19, 2014 | 08:42 PM
eagle670's Avatar
Sorry, bud.
Closing the vents has no effect on the airflow. I suspect that the switch is bad, but I want to be sure. Any help is appreciated
Old Nov 20, 2014 | 09:53 AM
PNA's Avatar
PNA
When you change the selector to defroster, does it flow properly to the windshield? If so, it may be the vent directional adjustment for the floor is stuck in a closed position. It would seem weird if it worked for one selection but then the other though. Not sure what to advise until their is more detail about the other operations of the switch. We'd need to look at the shop manual for location of actual operational parts, etc.
Old Nov 20, 2014 | 11:16 AM
eagle670's Avatar
The air flow does not change no matter what the position the switch is in. I have air coming through the vents and defroster, but nothing to the floor. If I close all the vents, still nothing goes to the floor.
I appreciate the help, I don't have a service manual, so I unsure what to check.
Old Nov 20, 2014 | 11:18 AM
The service manual is available as a .pdf from the link below.
( or click http://api.viglink.com/api/click?for...20%5B79.7MB%5D)
Old Nov 20, 2014 | 12:17 PM
eagle670's Avatar
Thanks for the link.
Old Nov 27, 2014 | 08:33 AM
robinsonparker's Avatar
A problem with the blower motor resistor can cause the heater blower motor to be inoperative (no air will blow from the heater vents). Proper diagnostic is needed to determine the cause.
Kodebuster
Nov 5, 2020 04:06 PM
Hoppy
Dec 7, 2018 07:36 AM
waldig
Jul 15, 2015 02:05 PM
ja.nko
Jul 10, 2015 03:21 PM
