Skreem module
Old Mar 12, 2015 | 11:00 AM
Bob B's Avatar
Default Skreem module
Just bought a 2004 crossfire with 51000 miles. Have read the the Skreem module may be a problem. Planning a trip south and don't want to worry about this problem. I noticed that there is no beep when I open or lock the doors. Is this A sign of a problem with this module. Should I have it checked or replaced?
Old Mar 12, 2015 | 11:20 AM
jmk41's Avatar
Default Re: Skreem module
If you can lock the doors remotely then the fuse that controls the alarm system hasnt been removed. This tends to be the case when the module is malfunctioning. If you had a new or slightly used key you would see instructions on how to turn the beep on and off. Hope this helps! Enjoy your trip!
Old Mar 12, 2015 | 11:24 AM
Bob B's Avatar
Thanks for your help
Old Mar 12, 2015 | 11:41 AM
Hawkske's Avatar
If you have the original alarm module , which is probably the case, it does not have a beep when locking/unlocking.
Old Mar 12, 2015 | 11:57 AM
+1 ^^^^^^^^^^^^^
The lights flash only without replacing the siren. The SKREEM has nothing to do with the beeping noise some cars have with the mod using the Radio Shack Piezo gizmo or the new alarm.
You are OK, so no worries.
REYMARTZ
22
Aug 7, 2021 12:37 PM
jhansen
21
Feb 15, 2017 04:26 PM
NORDVIK72
Aug 30, 2015 08:22 AM
NORDVIK72
Aug 25, 2015 11:43 PM
da pink
Aug 12, 2015 05:20 PM
