Manuel gear oil
Old Jan 21, 2016 | 03:01 PM
ozkancab's Avatar
Default Manuel gear oil
Hello I ve a 2004 v6 base manuel gear crossfire
I dont like the shifting on 1-2 and R
Maybe i would have better driving experience if i change the gear oil
Which is the right oil to use by the experienced crossfire users in this forum?
I ve read some thread about it but they were from 2011 and so thought it can be usefull to have an update as we are in 2016...
Thanks in advance for take your time and help me with ur answer for choice the best gear oil for my car
Old Jan 21, 2016 | 04:33 PM
Default Re: Manuel gear oil
We use SEARCH to find posts.
Here are some results using the words GEAR and OIL.
CLICK
Old Jan 22, 2016 | 05:49 PM
harbor's Avatar
Look here for discussions on this topic:
https://www.crossfireforum.org/forum...-question.html
If your '04 still has the orig factory ATF fill, that could explain the tough 1-2 & R shifts. Not sure what's available to you in Italy, but a syn 5W-20 motor oil, a dedicated manual trans syn fluid, or even a synchromesh fluid like Pennzoil or Valvoline should help. A clutch that's out of adjustment or needs to be bled could also be contributing to the issue.
Old Jan 22, 2016 | 09:27 PM
rush549's Avatar
Who's Manuel???
Old Jan 23, 2016 | 09:24 PM
Originally Posted by rush549
Who's Manuel???
I noticed that and thought it was an Italian driving a German car with a Spanish gearbox.
Old Jan 24, 2016 | 08:05 AM
ozkancab's Avatar
Thanks for replys i ve ordered redline from their england distributor.
Old Jan 24, 2016 | 10:13 AM
I put in Mobile 1 5W20 and noticed considerable smoother shifts.
Old Jan 24, 2016 | 10:28 AM
harbor's Avatar
Let us know how it shifts with the new fluid. If your going to DIY, l recall you'll need 14MM & 17MM hex drive bits.
W/outReward
Dec 27, 2015 11:15 PM
grip grip
Nov 12, 2015 12:06 AM
joeyrindone
Nov 9, 2015 11:46 PM
atdavis2
Oct 21, 2015 02:25 PM
Penniman
Mar 17, 2014 04:36 PM
