Won't start - very randomly
Old Dec 29, 2016 | 02:21 PM
AlexParra's Avatar
Default Won't start - very randomly
04 LIMITED COUPE - 40K MILES
This has occurred about 5 times now in the last 2 months. It has happened after being parked all night and after a quick stop.
When turning the ignition key on all the way there is no crank or sound of any kind; however, dash lights up and all bells and whistles seem to work at full capacity. I have used the cables to charge the battery and that works to get it start it again but I took it to Autozone and run a battery-starter-alternator test which resulted in a passing grade for all 3.
The crankshaft position sensor is on my check list but I'm not too sure since it doesn't crank when turning the key. Before replacing the CPS I wanted to hear other recommendations.
Thank You!
Old Dec 29, 2016 | 03:34 PM
Default Re: Won't start - very randomly
RCM, RCM, RCM. Did I say RCM ?
Old Dec 29, 2016 | 04:14 PM
AlexParra's Avatar
If I understand correctly, you mean to say is the RCM, right?
Thanks for sharing your knowledge.
One follow up question: Do I need to replace the entire RCM or are there other alternatives?
Thank you once again!
Old Dec 29, 2016 | 04:22 PM
Of course. Put it in a mailer and send it to tighed1 after emailing him at tighed1@hotmail.com
He'll supply the send to address and paypal info.
Old Dec 29, 2016 | 06:17 PM
curtisr's Avatar
Or you can fire up your soldering pencil and do it yourself. You Tube
"> You Tube
" type="application/x-shockwave-flash" width="425" height="350">
