Spoiler retracts at 60 MPH
Old Apr 27, 2017 | 07:25 PM
Spookymike91's Avatar
Default Spoiler retracts at 60 MPH
I own a 2004 crossfire coupe, it's a great car that I had since 2013. Last year, I had to disconnect a fuse in the fuse box because the alarm kept going off randomly. Now when I go about 60 to 65 MPH, I break the spoiler retracts. Is there anyway to fix this?
Old May 16, 2017 | 11:20 AM
liljay's Avatar
Default Re: Spoiler retracts at 60 MPH
Did you resolve this? The spoiler retracts at 40mph normally. When you break, what speed does the spoiler retracts. Deploy it manually and it won't detract until you detract it.
Old Aug 1, 2017 | 10:15 AM
perrino's Avatar
Can the spoiler be adjusted? (2006 crossfire convertible)
I would like for the spoiler go up at 75 MPH
Is there a simple adjustment?
Old Aug 1, 2017 | 10:26 AM
In simple terms, no.
Old Aug 1, 2017 | 02:37 PM
Kingdav1954's Avatar
🤔 Uuummm that would be a big fat no.,😀 You're just stuck with up at 62 and down at 35.
Old Aug 1, 2017 | 02:55 PM
It appears to be coded into the BCM, and no one has spoken of 'breaking the code' of the BCM.
IF it is in the ECM, (with the commands going to the BCM over the CAN bus), they why haven't Rudy or someone else found it and spoken of it?
No, no way to automatically deploy it using the BCM's output. You could design your own little box but I'm unsure of where you'd get a good indication of speed from without upsetting the applecart that is the stability control system.
Old Aug 1, 2017 | 04:01 PM
use a pitot tube from an airplane
Old Aug 2, 2017 | 02:25 AM
05roadsterguy's Avatar
You can put it up at any speed you want, and I believe put it down too manually. Not sure what your point really is, but the desired effect is easily manageable by the driver.
(or passenger)
Old Aug 2, 2017 | 09:42 AM
(or passenger)
Yoy can not retract it manually when the car is going 63mph or faster. It stays deployed until the car goes below @ 36mph OR you manually retract it when the car is below @ 62 mph.
