Rear hatch lock sticks
Old Apr 15, 2018 | 08:38 AM
Fun2drive's Avatar
Default Rear hatch lock sticks
When I try to open the rear hatch the latch sticks to the open position I have to manually pull the latch back in order for it to close how can I fix this
Old Apr 16, 2018 | 08:54 AM
Default Re: Rear hatch lock sticks
Do you have signs of rust around the latch? Maybe some oil squirirted through the licence light hole may cure it.
If there is rust find out what caused it.
Old Apr 16, 2018 | 09:04 AM
Fun2drive's Avatar
There is no visible rust anywhere on my this car
Old Apr 16, 2018 | 10:01 AM
Take the latch out and look at it.
Old May 2, 2018 | 04:24 PM
Goldwing's Avatar
It's easy for road dirt to get into the lock mechanism. Suggest opening the trunk, place a crummy towel across the trunklip to collect drip, and liberally douse it with WD-40 or silicone spray.
Old May 2, 2018 | 05:56 PM
I took my latch out and it was quite clean, no sign of dirt.
It has done 36,500 miles. I’ll add a photo of it.
Old May 2, 2018 | 05:59 PM
Fun2drive's Avatar
Thanks I will give that a try hope it works I did squirt a little WD-40 up in there but nothing like you're describing
Old May 2, 2018 | 10:26 PM
Wadsworth's Avatar
WD40 is a great degreaser and decent short term lubricant. The problem with WD40 is, it will gum up over time (1-2 years). I like to do an initial soaking with WD40 to degrease and then chase it out with a PTFE based lubricant. I usually use Triflow. The teflon base does not gum up overtime.
sg2848775
Nov 11, 2016 10:37 AM
FULLDRAWMIKE
Nov 19, 2014 07:35 PM
themush1326
Oct 18, 2007 02:59 PM
gatesy21
Sep 7, 2007 01:50 AM
FirebaseD
Dec 21, 2005 04:28 AM
