Brakes - brake pedal travel
Old Apr 2, 2019 | 04:41 PM
Default Re: Brakes - brake pedal travel
All I did to fix my excessive pedal travel, was to replace/bleed the DOT-4 fluid. After this replacement/bleed, the pedal was up tight and firm. Problem fixed...
Old Apr 2, 2019 | 05:12 PM
I believe we have at least two separate problems here and each has its own solution. Another problem is air in the ABS module which is not solved by just bleeding the brake system as normal. The pistons in the ABS module have to be actuated to remove air behind them. Unfortunenately the dealer has to get involved with this using their computer to operate the ABS system.
Old Apr 3, 2019 | 02:38 PM
The least expensive fix (especially if it works) would be the bleed/replace the DOT-4. A little time, no stealership visit/fee, and it just might be the only thing needed. Do the easy first, nothing lost if it didn't correct your pedal travel issue. KISS (Keep It Simple Silly).
Old Apr 3, 2019 | 02:45 PM
I have done that twice with no change, the car stops great but it is annoying.
Old Apr 15, 2019 | 02:22 PM
Ed Mahoney's Avatar
Worked for me , changed the fluid & pedal came right back up !
Old May 12, 2020 | 09:06 PM
forjox's Avatar
My pedal was soft after winter storage this year for the first time and the BAS/ESP warning light was on. Thanks to those in this forum for the advice that a good brake fluid bleeding will fix the problem. I used Pentosin Super DOT 4 fluid and bled each corner until fresh fluid came out. Now a nice hard pedal and NO light! Thanks again.
I really should know better as I bleed the brakes on my motorcycles every other year as recommended.
Old May 13, 2020 | 01:54 PM
Thanks for coming back and letting us know what fixed it. It also worked for me, sometimes not for others. Glad you got her back right!
Old Jun 11, 2023 | 03:09 AM
Nynick8's Avatar
Hey onehundred80, which dealership tool do you need? Can I use an autell scanner? Or do I need the big DRBIII reader? Also, how would you bleed the system with the tool? Actuate the ABS and bleed at home, or do I need to use the tool and bleed at the same time? Thank You (again)
glover
Dec 28, 2022 04:08 PM
redhors66
16
Mar 22, 2018 03:25 PM
redhors66
Jan 3, 2018 08:56 PM
Marshall2u
Apr 14, 2015 11:23 PM
smokey847
Jan 5, 2013 03:00 AM
