spoiler opens and remains open - it is a 2005
when reach 90 km speed it opens and when slowing down it remains open. even if stopped. pressing the switch does not help.
any advice? thanks an update: please see the last posts. found the problem and fixed it. |
Re: spoilers opens and remains open-it is a 2005
How do you get it down ?
Thanks, George, That was my question.
Originally Posted by zip439
(Post 925737)
When you turned off the ignition? |
Sorry Steve, forgot about that grommet, promise I'll look today.
when i started it was down. it then went up at 90kph but when slowed down it remained up. even when i stopped.
Originally Posted by phil alvirez
(Post 925753)
Unofficial weak/tired battery indicator/symptom?
Originally Posted by lovecross
(Post 925764)
Probably should take it to a dealer and let them "test the battery", that will cost around $100 for them to tell you the battery is OK. THEN, in a few days, take it back to them so they can test the battery again, and charge you another $100 to tell you they can't find anything wrong. THEN, in a few days, spend $125 on a new battery, if it fixes it, fine. If not, you go from there. But NEVER skip paying a dealer at least TWICE for nothing. OR, you could just replace the battery and go from there. (If your battery is over 48 months old, it's time for a new one anyway - if you love your SKREEM, seatbelt module and car in general.) |
any time when the car reaches 90 kph. so even if slow down and even stop, the spoiler remains open.
the only way to close it is by pressing the bottom of the switch and wait until it stops, then turning off the switch. i was suggested to remove the fuse so at least it is not deployed but then i need to know which fuse it is and where is located. any1? |
deleted. didn't see your last post
Fuse 20 in the undershood fuse box was the powered spoiler fuse in 2005, I believe.
But that fuse differed from year to year and between Base/Limited. You can try 20, but I'd consult the card on the underside of the fuse box lid, it will tell you which one it is. But keep in mind that ignoring this little symptom isn't really a good idea. The cause can be many things, and in some cases, the car's operation will eventually suffer due to what is going on.
thank you very much. will try and tell.
thanks again. |
tried but didnt work. thanks anyway.
What did you try? The Reset? The battery ground fix?
Keep in eye on the car, my bet is that other symptoms will arise soon, try to remember that any new issues MAY or MAY NOT be related to the spoiler having a mind of it's own. Example: If you start to observe odd behavior when trying to start the car.... |
Re: spoilers opens and remains open - it is a 2005
removed spoiler fuse. now spoiler remains down. but the red light at the switch flashes. i dont mind, but some1 can tell that it is o k?
I can't remember if it flashes due to a blown fuse - it may be flashing due to the error is it seeing in the first place - or it may be beacuse the fuse is blown.
I can't test it here, cause my car is off the road till the new top is on. |
i guess that it is telling that, as there is no fuse, it sees it as if the fuse is blown.
Could be a bad traction control relay in the relay control module.
Open the RCM (see video on YouTube), turn the key to the ON position. 2 of the 3 middle relays should remain closed (engaged). If not, bad relay. To verify - Manually close the relay, turn the key to the ON position and see if you can lower the wing. |
