Fusible link
Old Jul 24, 2019 | 01:50 PM
cheechwizard's Avatar
Default Fusible link
Hi, I have an 04 base coupe. I recently got into some deepish water, enough to blow out my fog lights. No prob taking care of that problem, but I have a constant battery discharge going on when it is running. I'm getting just 11 volts on my meter. Checked all fuses, battery is fine, cant find anything else wrong. So now I am looking for a fusible link I believe. I just cant locate it/them, or find any specific info on location. Any help with this would be greatly appreciated. I know what to look for, just cant find it on this car.
Old Jul 24, 2019 | 02:09 PM
Default Re: Fusible link
Also be sure you didn't get water in your trunk where the locking pump is!!!!!!
Old Jul 24, 2019 | 02:46 PM
Exactly what are you looking for? The line from Alternator to the solenoid/starter may be a fusible link, or it may not be - but from under the car, I believe it is easy to get to.
If the system is down to 11 volts with the engine running, the alternator is not charging.
But you did not say where you are measuring 11 volts at, nor what your ground reference is.
Old Jul 24, 2019 | 03:08 PM
Thank you gentlemen, it is the alternator. And this one does not have a fusible link. I appreciate this forum a great deal. Have already gotten A lot of useful info.
Old Jul 24, 2019 | 10:58 PM
Further update, removed alternator and it checked out good. Cleaned all connections that I could find that might have gotten wet. Put it all back together and no more problem. Guessing corrosion somewhere.
Old Jul 25, 2019 | 10:47 AM
Being an 04, it should have a BOSCH alternator.
But you make it sound like you got one of the VALEOs. I've changed the Valeo on my 07 twice now.
Do not be surprised if it fails again.
MattR97
Oct 11, 2004 09:51 AM
HDDP
Aug 5, 2004 12:05 AM
wonderdallas
Other Cars Etc
Apr 4, 2004 12:17 PM
glennnn
Jan 21, 2004 06:55 PM
texex91
Aug 7, 2003 06:50 PM
