Electrical issues?
Old Jul 29, 2019 | 11:11 PM
dre490's Avatar
Default Electrical issues?
Have a 2006 coupe, manual, 61,000 miles, original owner in Mamaroneck, NY. Anyone heard of electric seats working then not working! When it does work it’s only for a few seconds. Also thought the blower motor was bad so got one from auto salvage thinking that was the answer but that goes off and on at will. That’s where it all started first. At times it even seems to blow stronger then less. Alarm was going off in middle of night then it started to go off when driving so pulled the fuse, Have not had the “not starting” issue & hope not to. Anyone have any ideas to help or guide? Local Mercedes doesn’t want to touch it & local Chrysler doesn’t have a “class A” mechanic. Much appreciated if anyone can help.
Old Jul 29, 2019 | 11:19 PM
Default Re: Electrical issues?
All pretty common problems :
Seat - try replacing the seat relay.
Fan speed - try the control module connector repair first, then replace the fan resister board if the other didn't work.
Siren - batteries are NiCAD's they deteriorate and spit and leak all over the circuit board after some years - replace with a new module.
and :
do the sticky key fix
do the RCM resolder
replace the CPS sensor with a new Bosch one
welcome to the forum !
Old Jul 29, 2019 | 11:41 PM
dre490's Avatar
Thank you!!
Old Jul 31, 2019 | 04:09 PM
dre490's Avatar
Where should I look for these parts to purchase and what is the "sticky key fix? I am able to find a camshaft position sensor on amazon which says to fit mercedes slk320 and the Bosch crankshaft position sensor on amazon also. Where is the seat relay? For the fan speed you mention a resister board is that something that can be purchased? Sorry for all the questions, trying to get all the parts to have someone install as we can't do it ourselves. Your help is very much appreciated.
Thanks again!
Old Jul 31, 2019 | 05:30 PM
Old Jul 31, 2019 | 07:36 PM
dre490's Avatar
Tell me about it!😩 but maybe if I got the parts at least someone wouldn’t have to go look for it. U might be even lucky to get a friend to do it for us, thanks again! Glad I found this forum. Regarding the seat is it possible for both seats to stop working? Most of the time it doesn’t work but once in a while upon startup it does for a few minutes.
Old Aug 1, 2019 | 11:35 PM
dre490's Avatar
Regarding this seat relay, would that take care of BOTH seats? Also, would the battery have anything to do with these issues? I'm just trying to figure all these things out. Thanks so much for the help. Of course, now the headliner is falling down
Old Aug 2, 2019 | 01:30 AM
Yes, the one relay controls both seats.
Battery should read above 12v with engine off, 13.6 to 14.2 with engine running.
Old Aug 3, 2019 | 10:46 AM
direwolf's Avatar
Check fuses #21 & #22 .. right & left seat adjustment.
blower motor affected and RFID (skreem -- Start/No Start) is fuse #37
Old Aug 3, 2019 | 10:24 PM
dre490's Avatar
Thank you. Will see if they are ok. We really don't have a problem starting the car..
Old Aug 16, 2019 | 01:30 PM
dre490's Avatar
Where is this NiCAD battery and module?
Is it this? Tutorial on replacing the 2 3v150h Varta batteries in the alarm module. I found this on your list
Old Aug 16, 2019 | 01:32 PM
dre490's Avatar
Also, can you advise me where to get this battery or module?
Thanks so much
Old Aug 16, 2019 | 01:43 PM
It is cheaper and easier to just replace the siren with a new one. Just do a search on this site.
Old Aug 17, 2019 | 07:44 PM
Thanks so much
The batteries (2 needed) are available here ( https://www.ebay.com/itm/22279912721...m=222799127219 ) BUT you need to modify the one side so it has 2 pins. I believe 180 (Dave) has a .pdf on how he modded the pins on his 2 batteries. Good luck!
TRR
Jul 15, 2014 05:17 PM
Istrix
Jun 4, 2014 10:27 AM
TulsaXFire
Jul 8, 2010 09:46 PM
thejodbut
Oct 23, 2008 11:48 AM
marklodi
Aug 3, 2008 02:05 PM
