'04 with many electrical issues
Old Jul 14, 2014 | 04:46 PM
TRR's Avatar
TRR
Default '04 with many electrical issues
Hello All, new here, just made an intro, long time reader.
I'm going to make this brief, I'm just looking for threads or ideas I may have over looked to pass on to the repair shop.
Anyway, I believe I may have the RCM solder issue. The key fob fails all the time also. And I have the 'spoiler self activating' issue also.
I am at a loss, I am a mechanical engineer but electric issues are beyond me. The shop I take it to is stumped also. Their constant 'fix' - is - the battery was drained, we charged it, it's fine now. The battery has been replaced twice also.
After that, or simple charging - it runs fine. For a short while. And then - it does it again - key won't work, of course I can't start it, and it gets towed back to the shop where they tell me 'the battery is drained and you don't drive it enough'. But now I *do* ~
Something is wrong here, the root cause has not been fixed. I suspect it is this RCM issue - but I am not sure.
I plan to forward them that thread.
If there are any other ideas I can pass along to these people - this is the info I'm looking for. I do not plan to try to fix it myself because I have no tools / do not know electrical things.
Any info or advice appreciated! I'm on the W. Side of Chicago and take it to a sports / high tech shop that has other Crossfire customers. But they seem to be stumped / are convinced the battery is just going dead because I don't drive it enough.
Any info, advice, ideas appreciated!
Old Jul 14, 2014 | 05:16 PM
Default Re: 04 with many electrical issues
I suspect it is an ignition off high drain issue.
Connect a milliamp meter between the negative battery cable and the battery post and see what reading you get with the ignition off.
Should run 30 milliamps or so.
If a high reading, start plucking fuses till it drops, that will help to locate the problem area.
Old Jul 15, 2014 | 01:58 PM
TRR's Avatar
TRR
Default Re: '04 with many electrical issues
Thanks for the info Ala, I was thinking along these lines too / something is draining power, I wasn't quite sure how to articulate that and this helps a great deal. Will pass on this idea to the shop.
Thanks again
Old Jul 15, 2014 | 05:17 PM
I think the OEM figure is 15 to 20 ma.
Reliableron
Oct 17, 2015 10:19 PM
nataliefs
Oct 5, 2015 01:03 PM
bobbie
Sep 12, 2015 12:49 PM
RiderJC
Sep 7, 2015 11:19 PM
MickeyNasty
Sep 6, 2015 08:29 PM
