'04 coupe brake light go off on drivers side when you apply brakes
Old Feb 28, 2020 | 02:58 PM
Yvonne's Avatar
Default '04 coupe brake light go off on drivers side when you apply brakes
Help please. My brake light on driver side of 04 crossfire coupe goes out when I apply brakes. Any suggestions, thanks
Old Feb 28, 2020 | 07:23 PM
Default Re: 04 coupe brake light go off on drivers side when you apply brakes
Have you put in a new bulb lately or done something else?
Old Mar 3, 2020 | 02:19 PM
Yvonne's Avatar
Default Re: '04 coupe brake light go off on drivers side when you apply brakes
Yes sir
Old Mar 3, 2020 | 05:00 PM
Yes sir
OK, what did you do?
The bub is either in back to front or the wrong bulb.
Old Mar 3, 2020 | 05:25 PM
Yes, what number is the bulb you installed? Just any tail light bulb doesn't work well in the Crossfire.
Old Mar 3, 2020 | 05:43 PM
Yvonne's Avatar
Sylvannia 7528 LL is bulb I used. I matched the high and low side bulb pins and followed clockwise screw in of socket.
Old Mar 4, 2020 | 01:27 PM
The recommended bulb is a P51 5W or equivalent. They are available on Amazon. The little connectors on the bottom of the bulbs are different for the crossfires and sometimes others do not make good connections.
Old Mar 4, 2020 | 01:48 PM
Yvonne's Avatar
Special thank you to ZERACER for sharing the solution to my brake light problem. I will order right away. Have a blessed day!!!!
Old Mar 4, 2020 | 05:16 PM
Yvonne's Avatar
I went to Mercedes Dealership and purchased bulb and dash board brake light still comes on when apply brakes!!! Please help me somebody, Thanks
Old Mar 8, 2020 | 01:06 AM
lotsofspareparts's Avatar
With your engine running, how far down is your brake pedal going when you press firmly on it? Have you checked your brake fluid?
The dash board brake light has nothing to do with your brake lights. There is a separate light to inform you that you have a light out.
The only time the dashboard brake light will illuminate is if your parking brake is set, your brake fluid is low, or your brake pedal is going down too far when you apply the brakes.
Jared
Old Mar 8, 2020 | 01:16 AM
Yvonne's Avatar
Thanks Jared but I used wrong descriptive term , I meant the light bulb light that come on on dash that indicates a bulb is out. However at the Auto store I had it brought to my attention that the third break light on top of trunk lid was no longer working. And that could be reason . I am trying to determine the part number so I can order a new digital bulb. On line I see from $25 to $169 so I am totally confused. Anyone has changed the third brake light of 04 Crossfire Coupe and know part number, Please help me, Thanks
Old Mar 8, 2020 | 01:45 AM
Check all of your marker lights too, they will also cause the warning light to illuminate.
Jared
Old Mar 8, 2020 | 09:42 AM
There is a company that repairs the 3rd brake light, new ones are expensive. You could buy a used one but it may be busted as well. Others have had the nerve to cut into the light and fix for themselves.
Check that power is going to the 3rd brake light terminals before you start spending money though.
Old Mar 8, 2020 | 10:21 AM
Yvonne's Avatar
Thanks for this info Sir, I will check the power source cause I did have someone slam it down really hard when picking up voting machines and it may have broken the light. I have held off opening the cover but you just helped me see that I need to ... Thanks a million for your wisdom!!! Have a blessed day!!!
Old Mar 8, 2020 | 11:45 AM
That company is Cadillac LED Replacement 3rd Brake Light, Third Brakelights For Escalade, ESV, Escalade EXT, Avalanche LTZ, Chrysler Crossfire, 2010-2011 SAAB 9-5, 2015-2019 GMC Yukon, Yukon Denali Tail Light Repair,
Logan Diagnostic
209 Lighthouse Terrace
Franklin TN 37064 USA
615-479-1900
Old Mar 8, 2020 | 11:48 AM
Yvonne's Avatar
Thank you so much!!! I will contact them tomorrow!!! You have Wealth of knowledge and I appreciate your willingness to share!!!
Old Mar 9, 2020 | 09:42 AM
You cannot delete a thread, you can delete all your entries but the replies remain.
Old Sep 13, 2020 | 01:02 AM
Yvonne's Avatar
Thanks to everyone for helping me solve my brake light problem !!! The bulb was not connecting on one side of the little pin when you turn the bulb in the socket. Worked closely with the connection til I was able to set bulb in socket that allowed side pins to touch area needed for activation. Sincere appreciation to everyone!!! Yvonne
jmartinpadilla
Jan 8, 2016 06:30 PM
jmartinpadilla
Jan 6, 2016 07:22 PM
Wedge
Racing
Aug 11, 2009 06:34 AM
Veree
Detail Shop
May 18, 2008 06:19 PM
Thirteendog
Detail Shop
Jul 23, 2006 11:45 PM
