Wiper Drain Tubes
Old Feb 20, 2021 | 10:01 PM
srjoecow's Avatar
Default Wiper Drain Tubes
I removed the cowling and yes much debris on top of left and right drain tubes. Removed as much as I could and tried to run a weedeater line down the tube to see if they were obstructed; yes both sides. I water tested both sides and driver side does OK but passenger side very slow drip; hardly draining at all. I cannot find a good way to clear the tubes. I bought a 2 foot drain cleaner (plastic) meant to get out hairballs in sink. Drivers side tube has a nasty bend and it did not go far. I was able to get all 2 feet into the to "worse" side passenger side. But still slow drip.
How to get all the junk out? Compressed air; garden hose. The drain tubes are buried in the side panels of the car and the end underneath the car are not accessible.
Thanks,
Jim
Old Feb 20, 2021 | 11:42 PM
Default Re: Wiper Drain Tubes
The danger is blowing the end off at the top where it connects. I don't know how you would get in there to reconnect.
I did see a post a while back where someone successfully user compressed air.
If you go that route, start with the pressure turned waaaaaay down.
Old Feb 21, 2021 | 09:18 AM
Thanks,
Jim
Blowing air down the pipes may compress the debris tighter.
The passenger side pipe comes out by the windshield washer tank under the fender. If you have the time you could take off the fender liner, and clean out the area. I found a lot of debris hidden there, I had the tank out to replace it at the time. I generously sprayed the area with Fluid Film before putting the new tank back in place. Maybe you could loosen the debris from the bottom of the pipe if the liner and tank were out.
Cleaning the tank out is a smart idea if plain water has been used as slime grows in the tank in that situation, the first time I had my old tank out was because slime had jammed up the nozzles and pump.
You could try using a long Zip Tie that may go around bends more easily.
There is an How To on removing the WW tank.
Old Feb 22, 2021 | 05:35 PM
srjoecow's Avatar
I agree but I am worried about just compressing all together. Another XFire adventure.
Old Feb 23, 2021 | 01:10 PM
JoeO's Avatar
I cleaned out my drains using water hose set on medium then jet, back to medium, and finishing up with jet..........on the ground was a mixture of pine needles and leaves.
Replaced cabin filter same day and found the same. On the engine side of the filter I found a petrified mouse. Not a scared mouse, but a petrified one. In a geologic sense.
Old Feb 23, 2021 | 02:16 PM
srjoecow's Avatar
I had leaves and twigs on engine side too. No mouse 😜. I will give it a try. Thx
williammt
Sep 6, 2015 11:23 AM
Charismatism
May 20, 2015 07:32 PM
Robskytoon
U.K.
Jan 16, 2014 01:24 PM
onehundred80
May 13, 2013 10:33 AM
magredvet
Dec 16, 2009 11:13 AM
