Alternative cold air intake
Old Aug 15, 2021 | 09:21 PM
Stingthompson's Avatar
Default Alternative cold air intake
Does anyone know if this is a cheaper alternative to the need for speed cia
Performance chip tuning cia
Old Aug 16, 2021 | 01:05 AM
JSK's Avatar
JSK
Default Re: Alternative cold air intake
Looks like a hot air intake. I think the factory intake would be better.
Old Aug 16, 2021 | 09:07 AM
If you are really interested in this dual air intake system, it can be had for a lot less money from same vendor on eBay. Comes in Blue, Red or Black. Several Crossfire Forum members use this system, or something very similar. The car below belongs to James1549.
Chrysler Crossfire Dual Air Intake System
Old Aug 16, 2021 | 08:52 PM
I used the V8 MB airbox with intake tubes that run all the way to the core support. Air is brought in before the radiator.
Old Aug 18, 2021 | 10:46 AM
So is your airbox the one that comes as a 2 piece assembly that snaps together? The Airbox and the Engine Cover.
Old Aug 18, 2021 | 04:03 PM
There are at least three Mercedes air boxes that will fit the NA, l had three of them. Two I had were too high and rubbed hard against the hood liner, these went to the dump. The other one I had was 5/8” to 7/8” lower and did not rub hard.
It was a two-piece assembly, the nose piece and the part with the filters in it.
I’ll add a photo and the part number of the one I used. CLICK
It had larger intake holes in it and the Crossfire intake hoses fitted inside the box intake holes no on the outside. I used the Mercedes intake tubes that fit
Old Aug 19, 2021 | 10:03 AM
Just curious on which V8 Airbox & Engine cover fits the NA. I've got the actual Airbox, which is a 1-piece unit, for the MB SLK320 on my car. And I know it is different compared to the V8 version. Purchased mine new from M-B before they discontinued the V6 version. Came from Germany for about $85 including the filter elements. Is the V8 airbox required if you perform the throttle body upgrade?
RICKFRINK
Jan 17, 2022 11:16 AM
ala_xfire
Jun 19, 2011 07:46 PM
Chris L.
Jun 16, 2011 10:28 PM
murtazanooruddin
Mar 7, 2010 11:45 AM
CrossfireLTD
Feb 28, 2006 08:30 PM
