Help needed
Old Mar 24, 2022 | 08:12 PM
Paul Griffiths's Avatar
Default Help needed
Help
Bought a cf, just found out it failed mot cause previous owner took cat out, for me to put cat back on do I have to pay for two or is it one, so confused, I got a quote to put a cat on but am now worried when I get to garage they will say I need two, quoted £350 to supply and fit..
Old Mar 25, 2022 | 09:44 AM
UrbanE's Avatar
Default Re: Help needed
There is an upper and lower cat on each side
4 in total
Not sure if you can get away with 1 on each side
Old Mar 25, 2022 | 12:31 PM
Can I not buy this twin cat and use the existing pipe to run onto it? Saves having to buy two separate exhausts when I already have one on car.? So use the existing exhaust for say left and the one in pic for right, that way both pipes have a cat going through them
Old Mar 26, 2022 | 08:21 AM
Just asking, is this forum dead?, only ever seen two people on at same time and one of them is me lol?????
Old Mar 26, 2022 | 09:04 AM
zip439's Avatar
It isn't dead, but most are in N. America. I do not think running the car as you depict in that picture is a good idea. The measurements for temperature which the car uses for fuel injection control and the air pump at start up come from those forward converters. If you block a converter as the picture shows you will alter the temperature gradient measured between the two converters (Left and right) and thus the car will be getting bad info and will not run correctly. If you must restore the car go back to original piping.
Old Mar 26, 2022 | 09:20 AM
UrbanE's Avatar
“Is this forum dead?”
Pretty broad Statement with 3 posts so far.
All 3 posts have been in this thread.
jjames
Southeast Forum
Mar 12, 2024 04:56 PM
Black03AR
Mar 27, 2011 04:37 PM
BadBoy007
Europe
Feb 23, 2011 10:14 AM
Crossfire725
Jun 2, 2010 09:01 AM
cgocifer
Jun 16, 2009 12:24 AM
