Gas Leak
Old Jul 30, 2025 | 12:54 PM
Robskytoon's Avatar
Default Gas Leak
Hi, I have petrol (gas) leak at rear of car right hand side in area of pump & filter regulator - investigation shows its coming from the charcoal canister so potential candidates are purge solenoid valve which could draw fuel through if stuck open but unlikely because it does it without engine running or more likely a failing filter regulator where diaphram has corroded wondering how to prove maybe take connection from filter to canister off and see if gas leaks wirh ign on or some other way, ideas please and if canister is full of gas is it a good ided to try to empty to stop raw fuel being drawn into engine?
Old Jul 30, 2025 | 01:20 PM
zip439's Avatar
Default Re: Gas Leak
Lots of Info; use search box upper right corner type EVAP and use the google option by clicking "threads"
Best not to drive car untel canister is removed, gas drained and canister is dry before re-installing.
Old Jul 31, 2025 | 03:57 PM
xintersecty's Avatar
Working the same problem myself:
https://www.crossfireforum.org/forum...-canister.html
xintersecty
44
Sep 19, 2025 10:50 PM
beasticles
Sep 18, 2014 08:47 PM
Daddy
Jun 30, 2013 12:35 PM
Daddy
Oct 31, 2012 08:09 AM
donschorr
May 10, 2010 08:24 AM
