Dirty engine compartment
Old Oct 2, 2025 | 04:06 AM
Myopic's Avatar
Default Dirty engine compartment
Yesterday, I spent about an hour cleaning various parts of the engine compartment with a wet sponge and paper towels.
I wish I'd taken a picture before cleaning, so you could see how dirty everything was...
Do you also clean your car in this area?
Old Oct 2, 2025 | 07:43 AM
xintersecty's Avatar
Default Re: Dirty engine compartment
I got a steam cleaner for that purpose. It seems to work not great but it does work out some of the greaser spots out.
Old Oct 2, 2025 | 09:14 AM
dcskmail's Avatar
I try to keep it clean but dirt happens
Old Oct 2, 2025 | 11:21 AM
BPCR45-70's Avatar
A hand held "swiller" dampened with Simple Green works great for getting into and under tight places.
Old Oct 2, 2025 | 12:15 PM
Swiller does not compute.
Old Oct 2, 2025 | 04:22 PM
BPCR45-70's Avatar
Sorry. Spell checker got me. Meant to write "Swiffer". You know, those magic fuzzy dirt pickeruppers.
Old Oct 2, 2025 | 05:54 PM
Some ask me how I keep my engine bay so clean.
With a cool engine temperature I cover the alternator with plastic and lightly spray everywhere with a garden hose and rinse away dust.
Then go for a drive and let the engine heat dry everything completely.
Then simply detail with any product you choose to restore the black surfaces.
***I have NO oil leakage but if you do, spray oily area with Simple Green and allow about 10 minutes for it to penetrate areas applied before rinsing as I did here.
***Note: If you remove your OEM engine cover be sure to cover the throttle body (Air inlet) completely with plastic !!
Old Oct 3, 2025 | 01:08 AM
I wipe it clean with soapy water on a microfiber cloth. Then I use another cloth with clean water and wipe it down again. After that I go over all of the rubber parts with McGuire's Ultimate Black, and a quick detailer for the metal surfaces.
Old Oct 5, 2025 | 02:32 PM
Myopic's Avatar
Everything indicates that in America people take great care to keep the engine compartment and under the hood of their Crossfires clean.
Old Oct 5, 2025 | 03:29 PM
Only if it is a special vehicle.
Old Oct 5, 2025 | 10:16 PM
I do the best I can with my base model and my truck.
Old Feb 15, 2026 | 01:26 PM
Goldwing's Avatar
I try to keep both engine bays clean enough to eat off of. That means occasional hose sprays then detailed wiping down all the surfaces. Finally a good shining product from Mothers or Meguairs. I do the same for my Ghibli.
2005 Roadster
2005 Roadster
2018 Maserati Ghibli SQ4 GranLusso
Old Feb 16, 2026 | 05:34 AM
I follow Gary's protocol above for the most part. I typically dry off the engine washing using my leaf blower instead of taking the Coupe out for a short drive. Results I get are comparable.
Tony Curtis
Apr 7, 2009 12:48 PM
Tony Curtis
Apr 6, 2009 07:17 PM
jackei
Oct 30, 2007 02:45 PM
nox1s
Detail Shop
Oct 15, 2007 07:31 AM
golfdude
Detail Shop
Aug 24, 2004 12:10 AM
