power seats
Old Nov 2, 2006 | 06:15 PM
docxfire's Avatar
Question power seats
hi just wandering if anybody switched their manual seats [base roadster] to the one thats powered seats is this easy or needs a lot of work thanks.
Old Dec 29, 2006 | 01:20 PM
droptopxfire's Avatar
Thumbs up Re: power seats
Hey Doc,
I'm in the process of doing that. It appears that the wiring is there for the power, but not the heat. On my car the fuses are in the fuse box but the relay is not installed. Get relay # 5104857AA, ($26 @ your favorite DCX stealer), it plugs in behind the left hand lower dash ( you'll have to remove the lower dash panel)next to the steering column and you should be good to go.
Old Dec 29, 2006 | 03:40 PM
docxfire's Avatar
Default Re: power seats
thanks a lot really appreciate it, any special tools needed to remove the panel?
Old Dec 29, 2006 | 05:01 PM
spensley's Avatar
I don't think you need any special tools.
Just the usual - screwdrivers, maybe torx bits.
Do a search under 'knee bolster' - I attached the service sheet showing the removal of the lower LH dash.
Old Dec 30, 2006 | 10:24 AM
Phillips screwdriver, a plastic wedge to pop out the ac vent and maybe a small socket for the hex head bolts in the keyhole slots underneath...don't recall the size. the small cover right below the steering wheel needs to be removed to expose two more screws.
Valk
Jul 12, 2021 09:49 PM
Apr 28, 2016 02:04 AM
steps
Apr 26, 2016 06:21 PM
atdavis2
Sep 21, 2015 01:25 PM
steps
Sep 19, 2015 10:43 PM
